Go Back   N54Tech.com - International Turbo Racing Discussion > Model-Specific Engine Tuning & Modification Discussion > N54
Reload this Page Poll: What Temperature do you let your Oil warm to before going all out?
View Poll Results: What minimum Temperature do you let your Oil reach prior to targeting Max Boost & RPM
< 70c (158f) 2 4.35%
> 70c (158f) 23 50.00%
> 80c (176f) 11 23.91%
> 90c (194f) 6 13.04%
> 100c (212f) 4 8.70%
Voters: 46. You may not vote on this poll
codesx's Avatar
codesx codesx is offline
Default Poll: What Temperature do you let your Oil warm to before going all out? - 10-11-2018, 09:33 AM
Curious what everyone's comfort zone / magic number is in this regard.
At what temperature do you consider your car appropriately warmed up and begin to target max boost and RPM?
Myself - Knowing that the JB4 doesn't provide over stock boost until the Oil is past 70c (158f), I personally have been letting this be my guide.
I drive her gentle until > 70c (158f) and then I allow myself to hold the skinny down.
RB: Inlets | PCV Valve
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Default 10-11-2018, 08:46 PM
Once JB4 is active, then I smash. 160F
codesx's Avatar
Default 10-12-2018, 07:06 AM
I like the statistics! Glad I'm not alone!
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
Default 10-12-2018, 04:48 PM
Somewhere between 160-200f. Depends how patient I am.
N54 | Build Thread
SpoolnMS SpoolnMS is offline
Car: 2008 BMW 335i
Default 10-12-2018, 04:55 PM
I go off water temp. But oil temps are somewhere around 110ish at the coldest.
Limpmode's Avatar
Limpmode Limpmode is offline
Car: 2007 E90 335i
Default 10-14-2018, 07:46 PM
I go off water temp too. I get the water temps up to at least 190, then as long as oil temp is registering on the gauge I’m good.
You definitely want the oil warm, but engine operating temp (water temp) is more critical IMO. I guess you could look at it like this; water temps for engine, oil temps for turbos... as far as normal operating fits and clearances.
07 335i; JB4, Anti Lag, MHD BEF, BMS DCI, Phoenix CP, Tial BOV, MAP OC, BMS OCC, 1320 Down *****, MMP Inlets, RB Ext PCV, Mishimoto OCC, BMS Meth, N20 TMAP, VTT stock+billet comp wheels, Blk124 Wheels (5series take offs staggered), 275/35/18
Default 10-15-2018, 06:33 AM
Almost full oil temp. Being in Chicago and construction zones everywhere, rarely do you see a chance to get on it
2007 e90 335i
Hexon turbos
Fbo with Cpi tuned at e55
Jsr Custom tuned
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 10-15-2018, 08:25 AM
I wait till the gauge budges past 160F to get on heavier boost, but even then I don't rev too high until it gets a bit closer to normal. Depends on the outside temp as well.
codesx's Avatar
Default 10-15-2018, 09:23 AM
Interesting perspective.
My water is always hotter as they both warm up, so rarely pay attention . (though it's on my choice list of phone gauges)
I'll watch my water in colder and warmer weather to better understand their trending. (I usually watch the water vs. oil just in hot weather)
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
codesx's Avatar
Default 10-15-2018, 09:24 AM
My sympathies.
VRSF: DiPis | CP
HKS BOV
xHP Stage 3
NGK-97506 @ .020
Maintenance:
BOosted 335i's Avatar
BOosted 335i BOosted 335i is offline
Meth Addict
Car: E90 TiAG 335i Sedan
Default 10-16-2018, 08:05 AM
This is slightly off topic but part of,
Doesn't trans temp play a role here too?Say for auto.if your full throttle at 160f what about the trans temps,what's the safe number there for shifting,full load?
E90 335i Auto, Cold Weather, & Sports Prem. Package, Navigation
Mods
: JB4/MHD, ACF ST, Precision T/S 6062, AD-Eng Mounts, Precision RaceWorks Stg 3+LPFP, //HPF Exhaust Titanium Tips, Custom HighLow OCC, Precision RaceWorks Coils,RACE InterCooler, Custom Meth Kit, Justin(v8Bait)Tuning
rcpro88 rcpro88 is offline
Car: 535i
Default 10-18-2018, 11:55 AM
My trans temp stays right around 173F when up to temp. If I'm doing multiple gear pulls like drag racing/highway rolls I wait for my engine oil to get to around 190F or so, by that time my trans temp is at least 130F-140F. I notice the trans operates smoother when it gets warmer. Also keep in mind that you don't shift under full load, most people have autoshift boost reduction set to 60% or so as your transitioning from gear a to b, the trans is only under 60% load until you're fully into the next gear.
DON'T buy VRSF D.Ps or inlets! FBO, E85 Walbro 450, xHP trans flash
