threethirtyfive threethirtyfive is offline
Car: 335i e90
Default Mosefts Test Ok - Still Bad - 05-18-2018, 12:23 PM
Car was stored over the winter, went to fire her up and it barely lumps along, 30BB code, injector 3-6, DME failure, etc.
Pull the DME, test them, everything is good aside from the one of the two that sit off to the left, one side has a tiny squeak that does not sustain. Any other tests for Mosfets?
'07 e90
Default 05-18-2018, 12:39 PM
Sounds like you found your problem lol.
Car: 335i e90
Default 05-18-2018, 02:56 PM
Negative, replaced and still makes the short beep and car doesn't run. Time to pull the JB4 and PI. Fun.
'07 e90
