ganque's Avatar
ganque ganque is offline
Car: 2013 135i M Sport
Default 135i N55 vs M2, M3, M4 FBO & 335i N55 + Dyno Run! - 08-21-2017, 02:58 PM
Hey Everyone,
Just wanted to share some races that I ran last weekend at a private event at the local drag strip.
My car is FBO, with BMS WMI kit and FSB. MHD on Back end Flash (Pump map) and E30 mix in the tank.
UPDATE: *** Dyno Sheet uploaded ***
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 08-21-2017, 04:42 PM
Nice!
Mods: Stock for now
Default 08-21-2017, 06:01 PM
Nice runs!
Default 08-21-2017, 09:19 PM
Nice video...
That 135i with a DCT and a turbo upgrade will be deadly.
ganque's Avatar
Default 08-22-2017, 08:39 AM
Nice runs!
Thanks Terry! This was possible due to BMS and your amazing customer support, sorry for all those e-mails asking a ton of questions for JB4/WMI/BEF settings lol.
ganque's Avatar
Default 08-22-2017, 08:40 AM
Nice video...
Pure Turbo is already paid, Just waiting on my next paycheck for my Fuel-It stuff
Coming soon...
Mernardi Mernardi is offline
Car: 2011 135i
Default 08-22-2017, 10:43 AM
Good luck launching the DCT with Pure stage 2 :P I haven't had any luck. Proper drag tires might do the trick, but I'm also worried about snapping something.
ganque's Avatar
Default 08-22-2017, 01:17 PM
Then plan is to lower boost on 1st and maybe 2nd gear as well, and let 3rd and 4rd gear do the dirty job.
Stoolz Stoolz is offline
Car: 11 135i
Default 08-22-2017, 04:48 PM
Should work nicely(if you want to leave two 60ft long black lines).
Good luck tho!
ganque's Avatar
Default 08-23-2017, 06:53 AM
I was going to ask for your Tire/wheel setup, but I just saw it on your signature.
So, what's your best approach to this? How did you managed to get your best traction fix?
Car: 11 135i
Default 08-24-2017, 12:01 AM
Best way to launch I've heard of is to "catch" the launch control after initializing it then coming off the accelerator until rpm falls to around 3k then removing break pedal and stomping.
I haven't tried this because I had kickdown off in mhd last time out.
I hear you can ping a 1.8 but timing the light is impossible.
ganque's Avatar
Default 08-24-2017, 08:05 AM
Yeah I actually tried that method during the race vs the yellow M3.
Here's the raw clips when I tried the kickdown method:
Car: 11 135i
Default 08-25-2017, 03:15 AM
Says it's unavailable . How were your 60 foots?
ganque's Avatar
Default 08-25-2017, 11:51 AM
**** sorry brother, forgot to change the video status from Private to Public.
Unfortunately this track does not measure 60ft or even trap speed. They only offer the 1/4 mile time and reaction time. Best pass was 13.1 sec and a ~.580 reaction time.
This track is located at Mexico at 5500 ft above sea level, that's why the times are super high.
ganque's Avatar
Default 08-28-2017, 07:15 PM
I have updated OP with Dyno Run video and Dyno sheet.
405whp on a N55 E series!
ganque's Avatar
Default 08-30-2017, 08:05 AM
Nice runs!
Thanks for all your help Terry!
The car did a solid 405whp at the dyno and 493 ft/lb torque!
Next stop: PURE STAGE 2
houtan houtan is offline
Default 08-30-2017, 09:58 AM
any logs of dyno runs? Awesome result!
ganque's Avatar
Default 08-30-2017, 10:01 AM
Sorry, I didn't got any log during the Dyno runs. But here are the ones taken during the drag races vs the M3 and the M2.
