Mernardi Mernardi is offline
Car: 2011 135i
Default New N55 Pure Stage 2 - No Boost - 08-09-2016, 07:27 PM
Babied the car for the first 100 miles on my new turbo. My tech also re-installed my JB4 with the new turbo. I adjusted all user settings and flashed the large turbo pump back end. Just went to finally give the car some gas and I get no boost. The car was pressure tested and smoke tested so it's not a crazy leak anywhere.
The only code being thrown is 3BCF. I'm not sure what this code is based off of the fault code list.
I attached a short log, don't really want to drive the car as it is. You can see boost is hitting only a max of 3 psi.
Anyone have any idea why boost will not come even close to target? My shop is closed and I am furious right now lol.
JamCan335i JamCan335i is offline
Car: 2007 BMW 335i coupe
Default 08-09-2016, 07:52 PM
I believe when boost is far off target and PWM is maxed (or near maxed), that chances are there is a boost leak—it would seem yours is quite large at that.
2011 BMW 135i
Default 08-09-2016, 09:00 PM
+1
Car: 2011 135i
Default 08-10-2016, 06:32 AM
Hmm. The car was pressure tested and held 18 lbs without a problem. It was also smoke tested just to make sure.
I guess the fun begins in trying to track this down lol.
keyap keyap is offline
Car: N55 135i
Default 08-10-2016, 12:53 PM
That would suggest something's happened post install. There's no way looking at that log that you would hold 18psi without a problem
Newguy123's Avatar
Car: 12' 135i
Default 08-10-2016, 02:22 PM
Originally Posted by keyap
That would suggest something's happened post install. There's now way looking at that log that you would hold 18psi without a problem
+100.....
18’ Glacier white RS3
#PURETURBOS
#FUELIT
Car: 2011 135i
Default 08-10-2016, 03:39 PM
Thanks for the replies. Haven't had time to update today. Issue resolved. Vacuum line somehow came off of the wastegate. Glad it was something simple
