keyap keyap is offline
Car: N55 135i
Default BMS OCC - What Are The Battery Issues If The PVC Is Removed? - 01-24-2016, 01:42 PM
I've just fitted the BMS OCC to a E82 and would really like to remove the redundant PCV assembly however, the instructions say 'This must stay connected or battery issues may arise in some N55 vehicles.'
What are these issues? I'd ideally like to simply un-clip the unit and cover the remaining wires and was wondering, do these 'issues' refer to the fact that for some people the water pump continually runs resulting in a flat battery or does it refer to something else?
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 01-24-2016, 05:35 PM
Attachment 43938
Yep that's it. This can cause the water pump to run when the key is not in the ignition. Happened to me. Plugging this back in stopped it right away.
Car: N55 135i
Default 01-25-2016, 10:33 AM
Is there any other work round? I'd ideally like to remove the assembly.
Am I also right in thinking that this only happens on some N55s? If so, I may disconnect and see what happens.
Car: N55 135i
Default 02-04-2016, 05:39 AM
Quick update - I've had the assembly removed for the last few days and there appears to be no problem with the pump.
Is this something which happens instantly and every time the car's off or is it an intermittent issue which could start to happen at anytime?
Mernardi Mernardi is offline
Car: 2011 135i
Default 02-04-2016, 07:19 AM
Happened to me instantly. It's audible, you can hear it with the engine off and outside the car. The fix is connecting the JB4 power wire to one of the boost solenoid wires.
Car: N55 135i
Default 02-04-2016, 08:04 AM
Great - thanks. Thought I'd read somewhere that there was a work round
loesch's Avatar
Default 02-04-2016, 10:59 AM
It started on my car about a week after the OCC install. Was at my friends house and found my car with a dead battery when I left.
Car: N55 135i
Default 02-04-2016, 01:46 PM
Thanks guys - think I'll connect to the boost solenoid. Does it matter which wire I connect to?
Car: N55 135i
Default 03-13-2016, 02:34 AM
Thought I'd post a quick update as the PVC has now been off the car for a while - nothing too lengthy given the 'water pump' problem and resolution is well documented elsewhere.
My plans are to make the JB4 boost solenoid mod referenced by Mernardi and posted here. At present though I have the JB4 powered via the 50A fuse in the DME box and have the water pump problem but only in the following conditions:-
1. Car running - no problem
2. Car not running, locked and engine cold - no problem
3. Car not running, locked and engine warm - no problem
4. Car not running, unlocked and engine cold - occasionally the pump comes on
5. Car not running, unlocked and engine warm - pump comes on within a matter of seconds
Basically, I'm OK if the car is locked when not running
ddanieln ddanieln is offline
Car: 2011 E82 135i DCT
Default 09-27-2016, 05:01 PM
I'm having the water pump issue here...
Started having this problem about 3 days ago and I've been running jb4 ISO and bms occ for 3 months now without any problems up until now. Checked that the remaining connector was still connected to the old PVC heater thing. Also made the jb4 power through boost solenoid mod and still won't fix it..
The only "good" thing about my case is that it just stays on for a little over a minute after I turn off the car and then it stays off (I think so). It also turns on whenever I unlock the car (not sure if only when warm or also when it's cold).
I'd really like to fix this issue without having to dump my bms occ..
Car: N55 135i
Default 09-28-2016, 02:47 PM
I finished up running a separate switched live to the DME box.
This powers the JB4 and other associate mods.
Since install, I've never had a problem.
Default 09-28-2016, 03:24 PM
If you left the heater element plugged in then your problem is not OCC related. Maybe you need to also relocate your JB4 power wire?
Default 09-29-2016, 09:25 AM
Ok I'm still having the water pump issue... made a video for anyone interested to watch and point out if anything is wrong..
Something else to point out: Made my oil change about a month ago and I've driven barely 500 miles, however "low oil level" sign appeared on the dash coincidentally around the same time the water pump issue started. Though it might have been related but nonetheless I added 1 quart of oil, sing still popped up, so I added another one (for a total of two). A few mins later I prompted the in dash menu to give me a reading of the oil level and now it shows INACTIVE. This is where I'm really starting to freak out... started googling up if the water pump and oil sensors are related and it appears they are..
Sorry if I'm violating any kind of forum etiquete or rules by posting this from another page but I think this is really spot on of what I'm Experiencing:
The fact that the oil level sensor won't work properly when the water pump is running all the time might answer a question I had about how it actually works.
The oil level sensor is supposed to be able to tell how much oil is in the engine by how long it takes it to change temperature. I can understand how that would work when the car was below normal temps, but I was having a hard time figuring out how it could check it while you're driving down the interstate on a road trip.
This problem you're seeing would seem to suggest that they're altering the engine temperature using the water pump speed so the oil level sensor can take a reading. If the pump's running full speed all the time, the engine temp is probably just riding the termostat and there isn't enough of a change in the oil temp to get a level reading.
So there it is, it seems that if I solve the water pump issue then the oil problem goes away too... anyway here's the video I made just to make sure I got everything connected alright..
https://youtu.be/Jh1Ddw8-Jf8
Any help would be greatly appreciated!
Default 09-29-2016, 09:33 AM
See my post above?
Default 09-29-2016, 09:37 AM
Yes Terry thanks, that's exactly the connection I made and I still have the issue
Default 09-29-2016, 09:42 AM
Hmm so if after moving the power wire and reconnecting the OCC heater element caused the same issue it's hard to imagine how it might be related to your aftermarket parts. Try putting the car all back to stock?
Default 09-29-2016, 09:48 AM
Hmmm that would be ********* dp, intercooler, occ and chargepipe... I'll try first taking off the jb4.. just to be sure and I'll report back. Thanks for the support tho
Default 09-29-2016, 10:21 AM
Yes start with JB4 for sure.
Default 09-30-2016, 11:23 AM
Took out the jb4, pump still keeps running after engine shut off. Jb4 is not the problem, wanted to clarify that.
Iflickr.als Iflickr.als is offline
Car: Bmw
Default 10-01-2016, 05:07 AM
I need the pvc part number please
BMW 135i 2011 N55 Pure Stage 1 ETS Fmic , BMS Downp1p3 , BMS Intake , BMS OCC , BMS meth kit cm7 , jb4 ISO + MHD .
Car: N55 135i
Default 10-01-2016, 02:02 PM
Here you go.............
Name:  FireShot Screen Capture #1051 - 'RealOEM_com - Online BMW Parts Catalog' - www_realoem_com_bmw_e.jpg
Default 10-01-2016, 02:08 PM
If its not the JB4 then I really have no idea what else might be going on. Has to be electrical I'd think.
Default 10-07-2016, 08:17 AM
Ok so after 4 days of testing at the dealership they concluded it was the water pump itself. Really weird since I only have like 20k miles..
