AndersS's Avatar
AndersS AndersS is offline
Car: 335I Touring aut. 2010 N54
Default New silicone inlets. Time consumption? - 11-24-2015, 05:30 AM
How manny hours does it take a mechanic to install a pair of silicone inlets? VTT or RB?
My car is 335I aut. with Wagner Evo 2 IC.
Just had my mechanic on the phone, and he is not happy. Saying that there is almost no room because of the intercooler's ***** ?
What's your experience?
Update. 8.12.2015
The Shop used 16.5 hours on the installation work.
2010 E91 335I n54 Alpina B3 flash - JB4 - dp -BMS CP -Wagner FMIC Evo2 Comp. - RB Inlets - PURE Stage 2 - EOS PI - DV Irinium 5992 -Fuel-IT Stage3 Lpfp - KW Var1.- Trebila Performance flash E50
Rain's Avatar
Rain Rain is offline
Car: E92 335i '07 Manual
Default 11-24-2015, 05:46 AM
Interesting question since I'm planning the same setup in the future (but with MMP High Flow Inlets or VRSF ones ).
E92 335i, 2007, manual
Mfactory helical LSD, ST XA Coilovers, EBC Grooved Discs + Yellowstuff pads + Goodridge lines, 313 Performance wheels, OEM turbos
JB4 + Rev3, MHD JB4 BEF, BMS Clutch stop, Custom ©atless dоwnpipes, VRSF 7" FMIC, VRSF CP + Tial BOV, VRSF OEM Silicone inlets + OCC, Yokohama AD08R, BMS CDV
396 whp, 639 wnm (471 ft lb) 93-95 Pump gas, no meth, no ethanol
europartconnect europartconnect is offline
Car: e28 m5, e34 m5, e30
Default 11-24-2015, 05:58 AM
Your going to be quoted 6-8 hrs labor pending were you go but that's the norm.
E92 420 E92 420 is offline
Default 11-24-2015, 06:13 AM
I don't understand why the intercooler ***** would cause an issue?
UK V8Bait Tuned
Built Motor
TD Turbo 335i
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 11-24-2015, 06:34 AM
Yea that makes no sense. Tell him to stop being a bitch, cut out the stock *****, and ram these in there!
mykal's Avatar
mykal mykal is offline
Car: '09 E90
Default 11-24-2015, 08:03 AM
Remove fan and vacuum canisters, then cut out front inlet. Or he will have to disconnect intercooler up pipe and charge pipe to remove front inlet without cutting.
AndersS's Avatar
Default 11-24-2015, 09:31 AM
Just been out there.
It was exactly what he had done ( disconnected intercooler up pipe and chargepipe.)
But there was plenty of room in the front, and it is not near the intercooler pipe at all..
It was the boss at the shop who called me.
Maybe he was just trying to prepare me for the size of the bill. Time will tell..
Car: 2007 BMW E90 335i
Default 11-24-2015, 10:50 AM
Front will take 1-2 hours, tops. Rear 2-4 hours because you need to remove the DP's mostly.
2013 135is DCT Carbon Black
mmmcookies335's Avatar
mmmcookies335 mmmcookies335 is offline
Car: 2009 335i
Default 11-24-2015, 12:33 PM
I dont know about stock style inlets but I did my VRSF in about 2 hours including removing the DP's and adjusting and all that. Its really not a big job?
Milan's Avatar
Milan Milan is offline
Car: 08 335xi
Default 11-24-2015, 01:20 PM
That's what I was wondering too..if you are cutting out the stock inlets I don't see what could take any time?
09 335 - 6266
07 335i - 6870, E85 - SOLD
dawhiz's Avatar
dawhiz dawhiz is offline
Car: 09 335xi
Default 11-24-2015, 02:53 PM
I just put my RB inlets in. Time consuming. Looks like you might be able to leave ********* in and still be able to hacksaw out the rear inlet. With that said, *** don't take too long so removing them isn't bad either but does add more time. I removed the rear cback hanger for more clearance for a hacksaw. Cut out front to make it easier. The rear brackets take some time. The one holding the inlet on and the inlet retaining bracket. At walmart (here, last one) they had these ratcheting mini torx wrench that works perfect behind there. You want to remove all of the stuff lining the side of the engine (boost solenoid, etc) so you can fit your hand along the side of the engine back there and then your right arm and hand over the engine and around the back. It's tricky but doable.
All of these little things take time basically. 1-2 days by yourself probably.
This is for xi.
smitty513 smitty513 is offline
Car: 07 E92 335i
Default 11-24-2015, 03:35 PM
I got the front inlet on my friends e90 RWD in less than 20 minutes. If you have to cut front inlet, you might wanna leave the job to someone else. I also removed intake manifold to access the rear inlet. I was able to fully remove inlet off turbo and position it so I could cut it with Sawzall. Took two nights only because we did the oil filter housing gasket too and I left the gaskets at work
2008 535xi Sport
BMS DCI - ER Charge pipe - Synapse BOV - 5992s - RB PCV - E60 Sport Trans Flash/Retrofit - BMS OCC - DIY IC Piping - E30 - MHD stage1+
Stay tuned for my custom E60 inlets
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 11-24-2015, 06:29 PM
Done the install with rb inlets.
Intercooler ***** have nothing to do with it.
You only need to remove one dp.
You don't need to remove the fan.
AndersS's Avatar
Default 11-25-2015, 10:02 AM
How long time did you use?
Guess RB is almost same size and shape.
My isn't done yet.. So far. 13 hours + been used
He said that they are squeezed against the firewall and he is worried that they rubbing against the sharp edges of the cylinder head.
mistawall mistawall is offline
Default 11-25-2015, 10:22 AM
i dont think the guy really understood what he is doing. the rear inlet did take me a while. but i think he might be being overly critical of its placement. guys have done this on jack stands in less time..
TFT inlets, charge pipe TIAL BOV
RISS **, Exhaust
Walbro 450
335is Clutch
BMS short shifter
VRSF 7"
Montego Blue 1M clone
@breakmywallet (instagram)
matthewo matthewo is offline
Default 11-25-2015, 10:39 AM
Ouch, I hope they don't charge you for all 13. a competent shop that has a decent understanding of the n54 and or has been explained things they might need to do to accomplish the install should be able to do it in 1/2 the time easy. maybe they were wasting time trying to get the old ones out the wrong way or not removing enough stuff to gain access and wasting time that way.
when working on cars you have to find a happy medium between removing enough stuff to gain access and dealing with things that are easier to work around then remove.
If they went in to it without knowing they would need to remove the ***, boost silnoids, rad fan, and cut out rear inlet and have a small ratchet to remove the rear mounting bracket, then yeah I see how they could have wasted a lot of time.
I and a lot of others have been watching and reading for hours about inlets so, I am sure we probably understand a bit more of what needs to be removed and possible issues with the install, more then just going along and getting blind sided by them like a shop may.
Acetech Acetech is offline
Car: 03 M3. 98 M3. 11 1M?
Default 12-06-2015, 06:21 AM
Just installed mine in 1M, little extra difficult due to extra radiator and piping. Took 6 hours being meticulous, cut rear inlet removed front whole.
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 12-06-2015, 08:19 AM
My mechanic, did the front in less than an hour..rear took nearly 6 hours...this was the first one he had done. He said going forward they would quote 6 hour for the job.
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 12-06-2015, 10:49 AM
AndersS,
Sorry it is taking your guy so long installing our RB inlets. This has been the worst feedback thus far, as we have had feedback suggesting anywhere between 4 and 8 hours (typically around 6).
As for the squeeze, I understand what they mean- this is precisely why I designed our inlets with the 1.75" tube to not interfere (or be squeezed) through the area. Well that and that it has a much better connection to the turbo snout. But anyway as one can imagine, the bigger the tube is in that area the worse the squish. So the RB inlets you have are actually designed to have the most ideal fitment through that area, to minimize (or remove altogether) the excessive squish that could otherwise be encountered..
Anyway hope your installer gets it figured out, but all feedback thus far outside of your situation seems right on point.
Rob
cmiggz's Avatar
cmiggz cmiggz is offline
Car: 2008 BMW 335i
Default 12-06-2015, 01:33 PM
I just installed my rb inlets yesterday and took about 5-6 hours iv done 2 install one on mine and my budddies 335. Its honestly time consuming but very easy and hands on.
Unless you dont know much or havent taken stuff apart. Just my .02.
AndersS's Avatar
Default 12-08-2015, 02:55 PM
Hi Rob.
It is not RB inlets but VTT. Also 1,75" tube.
Sorry the misconception. I just took for granted that they have very similar structure as RBs and about the same challenges with the mounting process
I paid for 16.5 hours in labor.
Spending almost 4 times as much money at installation as the cost for the inlets alone.
I learned a lesson: Next time,I have to arrange a fixed Price before..
But most important is that the car runs great with the optional power..
Originally Posted by Rob@RBTurbo
AndersS,
Rob
Stalker
Car: 335I
Default 12-08-2015, 03:12 PM
Hi Rob.
This makes much more sense now. As stated prior (and found by your shop) is that 2" tubes through the squish area is not something that one would come natural to recommend. Unfortunately the 1.75" ends on the VTT units do not help make way through the squish either area, as the rear turbo squish area is further upstream than only simply the end. Your shop simply was pointing out to you what they felt was not ideal with the 2" hose being too large for that area.
Either way glad you got it worked out, but that amount of labor certainly could've installed some turbos at the same time and still with less cost.
Rob
thm8d thm8d is offline
Car: 07 335i
Default 12-08-2015, 08:13 PM
It took me 4 hours to do alone, then again.. I'm a mechanic and have many years of knowledge lol
Stalker
Car: 335I
Default 12-09-2015, 07:36 AM
thm8d, do you have the RB inlets?
Car: 07 335i
Default 12-09-2015, 07:40 AM
Correct!
