(#1051)
Leon@86 Leon@86 is offline
Car: Alpine White e82 135i
Default 09-20-2020, 04:56 AM
So no feedback an this bug on revision 15? Feel robbed now because I bought a feature that I cant use. NLS not functioning either. Please can anyone give feedback!
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 09-20-2020, 06:49 PM
Yea my 2 step does not work still.
I someone could explain the new settings and firmware to get it working again that would be appreciated.
Default 10-16-2020, 04:07 AM
Sooooo, still no feedback as to rectifying this issue?
brendan's Avatar
Brendan
Default 10-16-2020, 04:08 PM
The only way to control the engine is with an aftermarket ecu.
I have had everything working then next drive out they dont.
My boost by gear wont work.
Antilag works but timing stays retarded until I change gear. Defeats the whole purpose.
afr and portinjection flow not stable or contrable enough.
Once you get to a certain level jb4 can only do so much.
Default 11-23-2020, 09:48 AM
Can anyone please shed some light on what is going on with the issue on the 2 step not working anymore after firmware update?
Default 11-23-2020, 10:38 AM
No known issues so post up a JB4 log if you need assistance. If using a 2step make sure you have the latest v15 update for twin or v139 for single turbo.
Default 11-24-2020, 09:44 AM
There are multiple people a couple of posts back complaining about the same issue.
I dont understand what must I make a log of.... The 2-step with anti lag integration used to work, I did the update to v15 and it stopped working. One guy reverted back to v14 and it was good again, but this did not work for me.
As I stand now, no 2-step stand-alone or integrated and no NLS.
Default 11-24-2020, 10:47 AM
What isn't happening exactly that used to be happening?
If there was a firmware problem it would effect ALL users of that firmware not just one car for example. For example firmware older than v15 requires a clutch wire we no longer offer so anyone running 2STEP relay without a clutch wire needs v15 or newer firmware or it won't work.
If 2step/NLS isn't working at all for you, perhaps your 2step relay has failed?
Default 11-30-2020, 05:16 AM
Ok thanks Terry.
I will check the relay, just found it strange it stopped working only when did v15 update.
But I do understand what you are saying. It is strange only few cars are effected. especially AnilKram had the issue after update, then after going back to v14 it was fixed.
Will check relay and report back.
mattgu40 mattgu40 is offline
Car: 2009 E92 n54, 7''fmic, ********, jb4g5 2step relay, bms dci occ chargepipe synapse bov
Default 12-11-2020, 04:20 PM
Not sure my 2step relay is working as menu 8 is not doing anything / not activating. Changed relay doublechecked everything.
Tried it with MHD rev limiter/ launch control...
3.4k rpm 14psi
5200 rpm 26pis.
No way i am letting go of that clutch
AnilKram AnilKram is offline
Car: 09 135i
Default 01-08-2021, 12:47 PM
So do we have to purchase a new 2 step relay? I never removed the clutch wire from before either.
09 135I MT jb4 g5/MHD Trebila backend Frankenturbo F21 FBO, PI, stage 3 lpfp, full E85, Quaife LSD
Default 01-08-2021, 12:56 PM
Not had any mass reports of problems. If you need specific technical help just email us.
AWDGT2's Avatar
AWDGT2 AWDGT2 is offline
Car: 2019 AWDGT2
Default 01-08-2021, 02:19 PM
Any plan for this on the Stinger platform?
Bimmer_n54_e92 Bimmer_n54_e92 is offline
Car: 2009 335i xdrive coupe MT
Default Yesterday, 10:35 AM
Does anyone have the G5_ISO_32_14 file. I'm trying to revert back as my 2step/antilag integration stopped working after going to G5_ISO_32_15.
Much appreciated.
Default Today, 01:26 AM
Much appreciated.
You can download it on the same page as version 15.
Dont get your hopes up though, didnt work for me when I reverted back. Ive just given up because there are so many people complaining about this issue and there is no resolution.
Ive checked relay and completely redone my system to maybe see loose connection or something but it still doesn't work. Issue only started with Version 15 beta so there is definitely a bug or something.
Good luck and let us know if reverting back helped you.
Default Today, 07:13 AM
Same boat here, Bought new 2step relay new usb cable and new antilag chip. reviewed the wiring 100 times changed ground location... antilag sort of
work but 2step wont engage.
Default Today, 09:28 AM
I reverted back from G5_ISO_32_15 in the past and it fixed my issues. But then I went to v15 again and deleted my v14 file and now I can't revert back. It seems that only the newest firmware is available. No previous firmwares are shown. If someone could send me the file for G5_ISO_32_14 I would really appreciate it.
Default Today, 04:08 PM
Much appreciated.
Sure I'll attach it here.
Default Today, 04:09 PM
JB4 log running anti-lag?
