naughty140 naughty140 is offline
Car: BMW M140i
Icon1 m140i Log Check? - 05-14-2020, 06:37 AM
I would appreciate it if someone could take a quick look at my log. I know you guys are plagued with the same questions everyday, so I understand if it's tiresome.
I'm really keen to understand the logs myself, so if you could tell me what I should be looking out for, and roughly what it's doing to the car, that'd be great. (AFR, Trim & Target lines for example)
I installed the v15 firmware a few weeks ago. I just want to make sure everything is running OK. I'm pretty certain everything is normal.
Using map 1 for now, I'll knock it up to map2 and then 3 if the car keeps reacting positively. Running Shell V Power 97 octane fuel. Car is completely stock engine wise.
I've been running the JB4 since March 2019, but I deactivated throughout the winter as I don't push the car too often during those months it was running on the old firmware obviously.
I did 3 runs, I was going to post them in order, but I can't get the images to display via the insert image button.
I can also upload the log data if needed.
Default 05-21-2020, 12:14 AM
Please attach the CSV file.
Car: BMW M140i
Default 05-24-2020, 04:00 AM
Thanks. I'll attach them in order of the logs displayed.
Default 05-25-2020, 07:32 PM
Octane looks a little shaky. This is v11 firmware. Update to v16 and grab another map1 log for comparison.
Car: BMW M140i
Default 05-26-2020, 07:48 AM
Thanks Terry, sorry to waste your time.
I've just done two runs on the (hopefully) V16 firmware.
take a look if you get a minute.
Default 05-27-2020, 10:37 AM
Looks much better to me here, try map2 next.
