Car: Infiniti Q50 RS400
10-03-2018, 05:11 PM
Hopefully will have time this weekend to test fit these bad boys.
That looks good! We can’t wait...any ballpark price?
Car: Q50 Red Sport
10-03-2018, 07:04 PM
Originally Posted by Nate0490
Hey Terry did you get a chance to look at my logs above?
Is there a good tutorial or YouTube video on what we should be looking for in reviewing them on our own? It would be nice if BMS could create a YT video if there isnt one already. Thanks.
check this out for some detail on parameters: https://www.n54tech.com/forums/showthread.php?t=21269
Car: '18 Q50 RS AWD
10-03-2018, 08:33 PM
Cool. What do you look at to determine that more octane would help? Do any off the shelf octane boosters do any good? Trying to learn here so I dont have to bother you every time!
Torco has worked well for me for the past 7 years. Half can to a full tank helps to get octane from 91 to about 94 here in crap gas California. Really helps minimize the timing dips.
Can get 6 cans, so 12 tanks worth, for about $120 shipped on Amazon. Cheapest worthwhile fix I've found.
Although the cans aren't pour friendly... Dunno what the manufacturers deal is with that. I have to keep a lil funnel and pour spout bottle handy.
2018 Q50 RS400 AWD (w/Sport Mufflers)
Loving the ride...
10-03-2018, 11:26 PM
What is this for? And what are the benefits??
Car: Q
10-04-2018, 01:02 AM
Originally Posted by Boxy
At the time I noticed those issues I was actually running higher boost, around 20 psi lol. I don't push that high anymore but that's what I was getting at.
Still don't understand why my AFR shoots to 21+ while ECU is in lean spool mode though... Terry mentioned above it's supposed to be near stoich but also said my logs look fine.
What are your settings? you might want to back off of boost during lean spool range then, if you are not comfortable.
Car: Q
10-04-2018, 01:09 AM
Here are a couple of 0-60 JB times courtesy of Dragy on my 18' Q50 RS AWD:
- Stock : 4.79
- +4.5 : 4.43
Note: this is 0-60mph with NO brake torqueing
Mods : FBO (Intake + Exhaust + Gutted LDP)
I am actually currently tuned, but have been playing with the JB1 experimenting with it. Very impressed so far and a great bang for the buck!
Car: 2016 Q50 Red Sport
10-04-2018, 03:26 AM
I assume these will compliment the intakes you have. The dyno will help prove their ability.
2016 Q50 Red Sport
Ecutek tuned
Infiniti Sport Mufflers
10-04-2018, 07:46 AM
- Stock : 4.79
- +4.5 : 4.43
Wow nice gains!! Brake torque the crap out of it next time to see if it helps!
Car: Q50
10-04-2018, 09:15 AM
@Terry
Can you explain the benefits of the post MAF silicone hose prototype for us? I have an idea, but I bet you will explain it better.
10-04-2018, 09:58 AM
We'll have to see how fitment and testing goes as we haven't really tested them ourselves. In theory may improve spool and low boost response.
Car: Q
10-04-2018, 01:44 PM
yup, as well as hold higher boost for the same given turbo speed! Win, win, win...
(this is a similar post maf turbo hose compared against the stock accordion hose).
Car: 2018 Infiniti Q50 Luxe 3.0t
10-06-2018, 12:39 AM
@Terry
Can you check these logs and see how they look.
10-06-2018, 11:52 AM
Looks clean to me. I tend to like map5.
Car: Q50
10-06-2018, 12:32 PM
10-06-2018, 01:50 PM
Originally Posted by Q50GotSauce
Nice videos man, what map is your car on? Also i assume full downpi3s?
Car: '18 Q50 Red Sport 400
10-08-2018, 02:26 PM
What is the highest folks have done on their Red Sports map wise with E30?? I just did E30 last night and am going to try MAP 5 today, I've been on MAP 2 no issues with 93 pump gas.
Great site for calculating E85 and pump gas mixtures:
http://www.georgebelton.com/E85Calculator.php
Car: q50
10-10-2018, 07:56 AM
Just got a brand new JB1 for my 2016 Q50 (non-sport). Getting the similar problem with P0106,P0240,P0241 after the unit was installed. Checked the pins - AOK, none are bent.
Removed the unit, unplugged the battery overnight. Drove for a day without it, but CEL was still on.
Plugged back in and started getting System Malfunction message and the car stalled. Started the car again, and System Malfunction message disappeared, but CEL is still on and the car feels underpowered.
Originally Posted by VirusbetaX
Pics too big but codes are as listed.
P0106 manifold absolute pressure/barometric pressure circuit range/ performance
P0240 turbocharger/supercharger boost sensor B circuit range/ performance
P0101 MASS OR VOLUME air flow a circuit range/ performance
P010B MASS OR VOLUME air flow b circuit range/performance
10-10-2018, 08:10 AM
Short of a faulty cable harness and/or a bad JB1 board - I would suggest the harness connectors could be still not making a good connection. I have had good luck for well over a year with my JB1/JB4 connections using silicone dielectric grease. As you might expect, your mileage may vary.
Latest FW? -
10-10-2018, 08:33 AM
After reading several times, its not clear to me where we get the latest fw for our JB4s? Is it the 2nd post in the thread (by Ando) with the "JB4_Q50_OBDII_4_1.hex (46.4 KB)"?
Car: q50
10-10-2018, 08:34 AM
I did try to re-seat the contacts a few times.
Any chance to see if that's the issue w/ board?
Not feeling comfortable putting silicone on connectors yet.
10-10-2018, 08:48 AM
For JB4 owners - yes.
10-10-2018, 03:18 PM
I've done map5 with no issues. Now i run a custom map 6 with +6 @ 4k and 4.5k only. Feels better for daily driving. No bogging down
10-10-2018, 03:26 PM
On E30? Do you know what octane your E85 is? Trying to find the best E85 station in D.C.
Also, can you tell me how you have your custom MAP setup so I can try it? (Never done a MAP 3 custom before)
Do you have any bolt-on mods (intakes, downp1pes, etc)? Thanks!
10-10-2018, 04:31 PM
You can buy an E85 test tube on ebay for like $20. Summer is the highest grade (ethanol is seasonal), I tested 85% ethanol which is roughly 105 octane. Mixed with 93 you can obtain 96 octane = E30. Custom map is actually map6. I experimented with many custom maps, too much boost in low rpms can cause you to bog down and you dont nornally hit your target boost. Higher rpms tend to hit the requested boost more consistently. (Only mod is AMS HE) Try this out..
1500 3.0 psi
2000 3.5 psi
2500 4.0 psi
3000 4.5 psi
3500 5.0 psi
4000 6.0 psi
4500 6.0 psi
5000 5.0 psi
5500 3.0 psi
6000 2.0 psi
6500 1.0 psi
7000 0 psi
Reason: Missed key point
Car: q60rs
10-10-2018, 04:34 PM
Terry i just started noticing a high pitched whistling noise on acceleration. Here only during hard acceleration, AC is shut off and so is the audio. JB4 has not been installed yet been busy, still on JB1. There are no warning codes or MIL lights so i dont understand what could be causing this whine on acceleration? is it the turbos spooling? never heard it before. Also Performance doesnt seem to be effected either.
im having the same issue. for some reason could not recreate it at the dealer. so they did the throttle reset well types of re learning.
did u ever find out wt it was
