threethirtyfive threethirtyfive is offline
Car: 335i e90
Default Best tuner - Not looking to break records just want quality - 05-15-2018, 01:48 PM
Well I already blew a few hundred dollar last year after I finished my full MMP install with LSD, PI etc. I CLEARLY stated that I run MHD/BMS/BMS PI. He was all thumbs up, no problem and we spent an hour on the phone... After a handful of files and him recommending I spend almost $2k in more fueling and the car still runs worse than OTS tunes.
Everytime he sent me a file it would be non JB4, then he would talk about how much better it is solo. Great, as explain, I wanted a MHD/JB4 stacked tuner as I have JB4 and JB4 PI.
So, name away, the car has all the goodies, just need a turner and I would prefer one that actually operates as a stand a lone business.
Any recommendations?
'07 e90
Default 05-15-2018, 02:41 PM
Have you tried our of the shelf hybrid flashes? You should test one and dial it in before looking to pay more and having to wait for revision after revision etc. Load up our flash, make sure all jb4 values are as directed and log on map 1. Post it in the support section with your mods and fuel used and we can further evaluate for you.
LazYME870 LazYME870 is offline
Default 05-15-2018, 06:35 PM
Contact Trebila if your trying to tune Jb4/MHD BEF. He's the man you're looking for.
Car: 335i e90
Default 05-15-2018, 06:47 PM
I started fresh there this afternoon, sadly in the last three months of sitting my mosfets died Fixing this and then I will begin to tune with the OTS Backend flashes.
'07 e90
Default 05-15-2018, 09:11 PM
Can't go wrong with the OTS BEF stuff imho.
I bounced around a bit in my early N54 days- mostly flash only tuning w. multiple tuners (no really bad experience) just varying degrees of success.
I switched over to Jb4/BEF- the PI integration was a big draw + the support.
Long story short, Steve & I were able to get my old setup (Pure 2 Hi Flows + JB4 Hybrid-PI- BEF + S2 Buckeltess & DIY PI)- ran 10.9xx @ 133.5 in the 1/4- all with the OTS stuff, and making map 6 FB/DB adjustments after making passes. It's great not having to wait for a revision
Fix those mofsets & lets get to work.
psixtc's Avatar
psixtc psixtc is offline
Default 05-16-2018, 03:12 PM
I agree with the OTS tune statements above.
I was running a custom tune on my e85 ST 135i until recently and wish I would have tried the OTS maps sooner.
It feels like a completely different car (smoother & more power) and my wife even commented how how much better it felt when she drove it. If it gets the wife's seal of approval, it's sticking around.
Default 05-16-2018, 03:55 PM
Post your logs with the the OTS maps and let's see where you stand!
Car: 335i e90
Default 05-18-2018, 12:38 PM
Will do guys! Mosfets arrive today but I am a little worried as none of mine failed the continuity test
'07 e90
suspenceful's Avatar
Car: 2008 BSM 135i
Default 05-18-2018, 12:54 PM
Who did you initially use that you had problems with?
