09-12-2017, 11:10 PM
Yes, i have a g5 and map 0 forever that i flasher the car. But don't work  .
INPA, NCS EXPERT, MHD Etc work fine but xhp not connect.
Car: 09 335i
09-13-2017, 11:19 PM
Try uninstalling the xhp app then reinstall.
09-14-2017, 12:04 AM
i try in 3 differents phones..
1 hisense c20
1 samsung s6 edge
1 samsung s8+
not work.
any idea?
Car: 335i e90
09-17-2017, 07:35 PM
If you have to remove the JB4 to do any flashing you're doing something wrong. We along with hundreds of others load flash maps regularly with JB4 on map0.
This.
I have ran JB4 for five years now, never had to remove it for any flashing. That includes Aplina, BB, MHD and xHP. The auto map 0 makes it super nice.
I still think most people having issues are skipping the charger, it can cause loads of of issues if you dip below 12v midway through the process. Especially the first go with the backup etc. Car will start fine but your voltage is too low for flashing. xHP is very sensitive to this, MHD less so.
Car: 335i e90
09-17-2017, 07:37 PM
1 hisense c20
1 samsung s6 edge
1 samsung s8+
not work.
any idea?
Order their recommended OTG and DCAN cable, had the same issue. Cable that worked for my Alpina would not work. Got theirs, golden. Also, try un plugging and plugging the cable and connecting a few times.
09-18-2017, 01:17 AM
I have removed the jb and it has worked for me, something must happen with jb4.
I have tried with 3 different cables (tested in other cars and work perfectly), but in this IJE0S it is impossible to flash with xhp without removing the piggy back.
I would like to know why this happens.
Car: e92 335xi
09-18-2017, 03:39 AM
Not true. My car has IJEOS also and had no issues flashing xHP (recent) or various JB4 BEF's (a few years). Some have indicated problems might be related to using older JB4 firmware, mine is most recent minus 1 rev. Good higher amperage battery charger is important too. Using an older cheap ebay dcan cable + OTG adapter for xHP and BT cable for BEF. Never had to disconnect JB4.
09-18-2017, 03:51 AM
I'm very happy for you, and that you can do it without problems, but it does not happen to you does not mean that I tell a lie.
The jb has the latest single turbo firmware, I do not think that is definitely the problem.
Car: e92 335xi
09-18-2017, 07:20 AM
I never said you were lying, I have no doubt you are having problems but I doubt it is due to your car being IJEOS. If it is not due to some issue with JB4 single turbo firmware itself perhaps it is not having latest user interface?
My point was only that plenty of IJEOS + JB4 owners have flashed xHP/BEF without issues and some that did have issues when they updated firmware/UI problems went away.
Also xHP notorious for being very sensitive to voltage, I needed 10 amp charger else it failed repeatedly even on 2 amp charger, at least on initial install.
Car: 2010 e92 335i msport
09-18-2017, 12:12 PM
I've never had to completely my JB4 either, but just stated that last part because I remember reading somewhere that it was what XHP was suggesting. I've flashed with MHD tons of times, and also had no issues with XHP. Since the update to automatically go to map0, I've always felt safe about plugging into the OBDii port to flash something without having to manually check myself. Thank you for that!
Car: 335i e90
09-20-2017, 06:33 AM
I'd say with 90% certainty that he is not using a charger and that is his issue, or one that is too low in amperage. xHP is hands down the most sensitive flashing program when it comes to voltage, even more so than BB was.
Been happy with my xHP, I ran the Alpina as soon as it was uncovered. I felt that with Alpina the S mode was annoying as it would always hang at the top of the gear and I found myself having to speed up, let it shift, and then slow down a bit. D mode was unusable with Alpina, horrible. I used to only use M, I have actually started using the D mode with the newest xHP version, I find it's great for cruising.
I feel like S mode is obsolete, I can only assume people use it because they have stock or no paddles. One thing that still blows my mind are folks that have spent $10k on upgrades and still have the OEM shift paddles... Buy M3 paddles and you will never find a need for S mode, it makes M mode very enjoyable.
Car: 2008 BMW 135i E88 N54 6AT
09-20-2017, 08:00 PM
Upgrade to Stage 3 v1.4 and give it a go - you might be pleasantly surprised. I'm a habitual manual shifter but v1.4 has got me driving in S mode because it's so good.
Why do you say the M3 paddles are better than stock? I agree they _look_ better, but functionality wise, what's the difference? I've re-wired my stock paddles so the left hand polarity is reversed (pull for downshift like normal cars, push for upshift).
I'm reluctant to change to M3 paddles because this way I can upshift or downshift from either side of the wheel, which is convenient when you've got the steering wheel inverted or got only one hand on the wheel.
But i've never driven or used M3 paddles, so I'd be interested in your experience.
09-21-2017, 01:06 AM
at the end remove the jb4 and I could do the flash without any problem and fast.
what surprised me is to see that you talk about stage 3 version 1.4, I just left to install version 0.9 and 1.0
Car: BMW 135i Coupe
09-21-2017, 07:33 PM
I second that opinion.
Just flashed V1.4 earlier today and S mode is wonderful.
Downshifts from 3rd into 2nd happen at just the right moment for taking corners.....it's as if the tranny reads my mind.
09-22-2017, 07:38 AM
ok... i know because only have a 1.0
My TCU is hw 7566894... i have bad lucky.... pre 03/2007...
09-22-2017, 06:02 PM
if you have issues with flashing or crash during flashing, just take off the JB4 from the ECU, flach and reconnect jb4, I had the same issues, everytime it was the solution to successfully flash.
good luck
Car: e92 335xi
09-24-2017, 12:48 PM
There's now a stage 3 v 1.5 out, or was when I checked this AM. Notes say only change is it stays in 6th in sport mode longer without downshifting. Going to try it here in a but.
Car: 2008 E93
09-24-2017, 02:58 PM
It says it will stay in 6th for CRUISE CONTROL
Car: e92 335xi
09-24-2017, 04:46 PM
Ooops you're right.
Car: 08 E60 535i
JB4 removed or MAP 0? -
11-07-2019, 05:02 PM
Hi Terry. Since it's been a while since the post about flashing XHP with the JB4 removed thought I'd see if anything new has come up. Ready to flash XHP and not wanting to remove the JB4 tonight. Still seem fine to just go to map 4 and do the flash?
Haven't seen anything contradicting your comment other than XHP stating to remove it completely. Sounds like JB4 MAP 0 is about the same thing or at least good enough.
Still the final word?
Brandon
Hayden, Idaho.
* 08' 535I. * JB4 W/ Bluetooth Connect & custom tune. * Billy Boat 535I 3.5" *****-back exhaust W/ resonator delete. * BMS DCI. * NGK 2 step colder plugs @ .020" (And I mean .020" on money!). * New Eldor coils. * BMS BOV adapter and BMS Vac side OCC. * BMS Chargepipe. * TIAL BOV W/ Hard 1/4" Vacuum line W/stock spring. * XHP Stage 2 * C-@-T TUBES.
[/SIGPIC]
Car: 335ix
11-07-2019, 05:18 PM
I've had no problems flashing XHP with the jb4 installed using the latest firmware. You'd want to switch to map 0, not map 4, as canbus is still active on 4.
Car: 08 E60 535i
11-07-2019, 08:05 PM
Sorry, I meant MAP 0 lol. Glad you pointed it out though so I didn't accidentally steer anyone wrong.
Trying to tune my BEF flash in still but guess it wouldn't hurt to get the tranny snapping good again in the meantime.
Brandon
Hayden, Idaho.
[/SIGPIC]
Car: 2008 E93
11-08-2019, 12:38 AM
There shouldnt be a need for map 0 in latest firmware. Even a few revisions back still the same. Jb4 detects OBD II plugged in and automatically goes to map 0. Terry made it truly plug n play.
Car: 335ix
11-08-2019, 09:51 AM
That doesn't seem to always work right away, though. I've seen MHD want to do full writes a few times, which is fixed by backing out and letting MHD talk to the ECU again.
Car: 2008 E93
11-08-2019, 10:20 AM
Which still indicates that OBD II is connected and reading. Otherwise it wont let you connect for a 2 min flash or 30 min flash. Meaning , jb4 is letting it communicate. That is most likely a different issue. Depending on phone or tablet, there can be a sequence of what gets plugged in first in order for things to operate properly.
