bobbyh907 bobbyh907 is offline
Car: 2012 135i DCT FBO
Default High load misfires problems. Help! - 07-05-2017, 04:32 AM
FBO 135i n55 DCT on a wedge Performance tune. Getting misfires under high load. Happening on cylinders 1, 3, 4, and 5. Brand new coil packs and brand new OE plugs. Fuel rail pressure staying above 2k psi. One log showed 1940psi(lowest it got). Does it on pump tune and 96 octane race fuel blend tune. Ran 100 octane through it to see if it was ****ty fuel and same misfires. Any ideas?
keyap keyap is offline
Car: N55 135i
Default 07-05-2017, 07:45 AM
Post a JB4 CSV log. Ideally 3rd or 4th gear - start at 2500, go WOT until redline..
Default 07-05-2017, 12:54 PM
I don't use jb4. I use mhd.
bNks334 bNks334 is offline
Car: 135i (N55)
Default 07-08-2017, 11:34 PM
What's your spark plug gap at?
Mernardi Mernardi is offline
Car: 2011 135i
Default 07-13-2017, 07:35 AM
Did Wedge give any ideas on what he thought may be the issue? Could be the fly wheel causing problems. DCTs have seen misfires resolved by upgrading to the M4 flywheel. MFactory is supposed to be releasing a kit as well.
Every once in a while I will see a high load misfire as well, and I believe this is my issue. Pure stage 2 Wedge tuned E30. You being just being FBO, it may not be the same issue.
