livnpaintball2 livnpaintball2 is offline
Car: 135
Default Tranny porn - 01-28-2015, 03:36 PM
I'm rebuilding my trans since its out of the car and need the specs for the steel plates, anyone have it? The ones I measured are 2.38mm.
2016 Mustang GTPP Whipple! 650rwhp, easy..
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Thor 12.9 mega motor installed!
Car: 135
Default 01-29-2015, 10:02 PM
They are 2.4mm stock. Getting the manual shipped to me so I can check all the specs and get it right.
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Car: 135
Default 12-11-2015, 02:31 PM
Happy to report my trans rebuild fixed all of the problems I had, no more flared shifts or slipping!
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
nyt nyt is offline
Car: 335ix
Default 12-11-2015, 04:18 PM
Did you do a stock rebuild or did you upgrade anything?
EvanL's Avatar
EvanL EvanL is offline
Car: 07 E92, 08 E61 (N54s)
Default 12-11-2015, 04:58 PM
Congratulations, you made the only thread ever to be titled, "Tranny porn," that I am willing to click on.
That said, good luck!
'07 335i, '08 535xiT
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 12-11-2015, 06:14 PM
Can you post a link for all parts?
EJ_3's Avatar
EJ_3 EJ_3 is offline
Thumbs up 12-11-2015, 11:52 PM
I concur! Hope no one Google 'tranny porn' to get the reference. It's not at all car related!
Default 12-12-2015, 07:11 AM
Lol, had the same thoughts
N54 | Build Thread
Car: 135
Default 12-12-2015, 09:47 AM
Thectsc.com for the ZF parts and eBay for the Sonnax Zip Kit. I did have the converter rebuild locally and they brazed the vanes and installed new bearings and seals.
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
jeison33 jeison33 is offline
BoostingSix
Car: BMW 335i
Default 12-12-2015, 02:03 PM
Some needs to do a diy trans rebuild on video and sell it.
Corrupted's Avatar
Corrupted Corrupted is offline
Default 12-12-2015, 05:57 PM
I felt quite the opposite.
Car: 135
Default 12-13-2015, 11:51 AM
If anyone wants the 6hp26 manual just hit me up.
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
SCGT SCGT is offline
Car: 207 335i 6MT
Default 12-13-2015, 12:22 PM
lol
Race8877's Avatar
Race8877 Race8877 is offline
Car: BMW 135I
Default 12-13-2015, 12:54 PM
I want to see a solution for the AT tranny N54.Where you can hit 800HP without
any slippage or TC problems. DCT is doing pretty good with does upgraded
clutches(Dodson).800+.Sh*88%$#t.
FCobra94 FCobra94 is offline
Car: '07 E90 335i
Default 12-14-2015, 08:24 AM
I'll take one, if you got a digital copy, etc. TIA
How was the rebuild overall though? Pretty straight forward if you follow the manual?
Car: 135
Default 12-14-2015, 08:39 AM
The manual is just for reference, it is not the same as the 21. Email address?
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Car: 2007 BMW E90 335i
Default 12-15-2015, 03:48 PM
Can you list out the problems you had and the exact parts you replaced? I'm having issues with inconsistent shifts. I was thinking of doing the zip kit and replacing all of the solenoids, but that's a lot of $$$ to spend on a hunch.
2013 135is DCT Carbon Black
Pure Turbos's Avatar
Pure Turbos Pure Turbos is offline
Default 12-15-2015, 04:20 PM
Insider ZF knowledge:
Replace your Front Stator bushing with the Omega upgraded part:
http://www.omegamachine.com/db/ZF6HP...hing%20kit.asp
The front stator bushing is what causes most 4th, 5th, and 6th gear problems. It can be done without disassembling the whole trans.
The front stator bushing is not only a shaft support bushing, but more importantly: seals oil pressure to the E clutch (4,5,6). The OE ZF bushing is inferior, the bearing babbitt fails especially with increased torque.
Our shop 135i OE bushing was worn out, with a measured clearance of .008", OE spec is .0015". The excessive wear bleeds off the much needed engagement pressure for the E clutch.
Most ZF6HP21 trans problems are caused by this bushing. But of course, trans shops won't tell you this.
Default 12-15-2015, 04:44 PM
How difficult is this to change? When I rebuilt my 4L80E the bushings were a nightmare, not only to remove but to put in straight, especially without a press. I used a bushing driver kit but it didn't really help.
Default 12-15-2015, 04:50 PM
Bushings are easy to replace. Similar to popping new bearing races in a hub. Hammer out the old with a punch, tap in the new with a bushing driver kit.
jdm5596 jdm5596 is offline
Car: 335xi
Default 12-28-2015, 09:34 AM
Subd... this is interesting.
Car: 335xi
Default 12-28-2015, 09:35 AM
jdm5596@gmail.com
Can you please send it to me as well? Appreciate it if you do.
europartconnect europartconnect is offline
Car: e28 m5, e34 m5, e30
Default 12-29-2015, 10:11 AM
I'll take a manual as well. Willing to paypal you for your time.
Car: 135
Default 01-02-2016, 08:03 PM
Send me your email!
08 135i-sold!!
DCI
JB4 Iso5
Dp
VVT stage1
Berk cb
7" intercooler
Chargepipe
Wavetrac
Car: '07 E90 335i
Default 01-07-2016, 07:14 AM
Great info! Thanks for sharing!!
Speaking of trans shops, there doesn't seem to be a notable/common name trans shop that E9x folks can rely on to send their slush boxes to for refresh/rebuild services.
Do you guys at Pure do this work and/or can you recommend a shop that we could send our auto transmissions to for reliable service? Even if someone could offer a nice rebuild + core option and knew what they were doing (by using upgraded parts such as the bushings you mentioned above, etc.) I think it would prevent peeps from having to take a gamble on junkyard trans options when their stock pieces have issues in the future; or even worse, have to rely on local shops for a rebuild which more than likely have no idea what they're doing in the first place.
