(#226)
Default 01-06-2015, 02:36 PM
Latest dyno results: http://www.n54tech.com/forums/showthread.php?t=28341
F30George's Avatar
F30George F30George is offline
Car: f30 335
Default Vargas Stage 1 Turbo F30 - 01-17-2015, 10:10 PM
Hey Guys,
I was able to get on a dyno recently and pretty happy with the results!
Vargas stage 1, ISO, DP, ER FMIC, Meth, E35 Mix.
417/436 was my best uncorrected had some spinning on the dyno from the snow tires currently running.
frefer82 frefer82 is offline
Car: 2011 135i N55 DCT
Default 01-19-2015, 09:48 AM
Hello to all.
i want to install a stage 1 turbo and want some info.
best turbo (less lag if there is any, best spool)
my car have this:
im goint to buy the N55 stage 1, anbd i want to know ehat else do i need to do the install, my car have the following.
JB4 stage 2
injen intake
CPE charge pipe
BMS meth kit
AR ******* down pipe
ER intercooler
AA catback
i read that i can use the oem maps, the one that comes with the jb4, but want to know if there is anithing that i can change (tune map 6) to get the most of it ???
j23a45m's Avatar
j23a45m j23a45m is offline
Car: 2011 E90 335i
Default 01-19-2015, 09:50 AM
Originally Posted by frefer82
Hello to all.
my car have this:
JB4 stage 2
injen intake
CPE charge pipe
BMS meth kit
ER intercooler
AA catback
That is your own research there
2011 BSM 335i E90 MTECH 6MT • BMS Intake • Vishnu c@t less DP • Cyba Scoops • LUX V4 H8 • 6000K Headlight/Fog light Morimoto • Euro headlight switch • ACS roof wing • 35% tint • Black Grilles • Misc coding • JB4 Stage 2 • AA charge pipe • Vrsf 7" FMIC • M3 cluster •
Default 01-19-2015, 10:14 AM
Stage1 turbos are similar enough to OEM there are no special requirements for them.
JETmn JETmn is offline
Car: 2011 335xi
Default 01-19-2015, 11:31 AM
I am running my stage 1 with just JB4 and CP (FMIC and DP waiting to go in). You can run a special map 6, but I find map 5 is working quite well too.
Default 01-19-2015, 12:46 PM
So y can run map 3 and nap 7 without any settings ????
That's great
Default 01-19-2015, 01:04 PM
And do I need the flex fuel cables ???? I don't have those and can find them on BMW page
Default 01-22-2015, 08:26 AM
another question i buy the pure stage 1 it will be here in colombia for the 27-30 jan, i buy the flex fuel cables and i read there its a improvement with 3.5 bar sensor swap or this its only for stgae 2 turbos???
what else do i need interms of tuning i read that a backend flash or this its for stage 2 turgo too.
Nugs Nugs is offline
Car: 2011 135i
Default 01-22-2015, 07:36 PM
You don't need the 3.5bar sensor unless you plan to go over 21psi, which you shouldn't with a stage 1.
Backend flash is a good idea if you can do it.
Default 01-29-2015, 09:08 PM
Hello all today i instal my pure stage 1 but dont feel any diference here are 3 maps 2 in map 3 and 1 in map 5
Attachment 27483
Attachment 27484
Attachment 27485
Default Help - 01-29-2015, 09:12 PM
and have the error code 2BC1 please help
and have this error code 2BC1 help
Attachment 27483
Attachment 27484
Attachment 27485
Default 01-30-2015, 09:14 AM
The one log I looked at is low boost. I'd raise the additive...
Default 01-30-2015, 10:32 AM
Ok terry but the additive it's on 42, what's the highest I can run ????
Peter @ Pure's Avatar
Car: F20 M135i
Default 02-13-2015, 02:04 PM
Whats the best fuelling option for us N55 with new style hpfp?
Vtt hpfp solution wont fit. That leaves port injection, upcoming fuel it tb injection and meth.
Whats your opinion Terry? What integrates best with jb4 + failsafes etc?
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 02-13-2015, 02:08 PM
For an F30 I'd just stay with meth, for now.
Car: F20 M135i
Default 02-14-2015, 12:08 AM
Any technical details why you think meth is best option for us F series guys?
The 135i with vtt st2 runs meth as well i take it?
peter@pureturbos.eu
pureturbos.eu
Default N55 pure stage 1 - 02-18-2015, 08:32 AM
hello mates.
tiday i made my first map 6 run tests, and want to know how the car its runing this its the settings im runing on map 6, any advice will be great.
Attachment 27830
Attachment 27831
Attachment 27832
Default 02-23-2015, 05:37 PM
For anything < 500whp meth provides a proven & affordable solution. If you are shooting for > 600whp then PI is probably the way to go. But, we've done zero development on it. PURE is the only company I know currently testing it out. So I'd get with them for feedback on how effective it is for the application.
Stoolz Stoolz is offline
Car: 11 135i
Default 02-24-2015, 03:04 AM
Hi Terry, I'm running a 2011 135 DCT.
I have bms intake, chargepipe, intercooler, occ, oil tstat, jb4 iso 5.5 plus flex, stage2 lpfp and n20 tmap. Not running meth!☺
Am installing vtt s2 next week and was planning on running map 5 on 60% e85 40% 93 pump along with your cobb back end flash.I will post logs to the support section, just wanted to know if this seems like the right set up initially,
Cheers,
Stoolz.
Car: F20 M135i
Default 02-24-2015, 03:07 AM
Cheers,
Stoolz.
My guess is you will run into fuelling issues if you up the boost.
peter@pureturbos.eu
pureturbos.eu
Car: 11 135i
Default 02-24-2015, 04:42 AM
Page one of this thread Terry mentions the hpfp could handle up to 60% Ethanol.
I wont wind the boost up it will be map 5 preset.
Car: F20 M135i
Default 02-24-2015, 06:41 AM
Yes map5 will run boost based on octane. Since your octane will be pretty high with E60 you can expect high boost. High boost means more air, more fuel needed. Hence I think your hpfp might not flow enough.
peter@pureturbos.eu
pureturbos.eu
Car: 2011 335xi
Default 02-24-2015, 07:29 AM
Maybe that was with an upgraded LPFP? Several of us have found we can't go nearly that high. I am on a stock fuel system and E40 is my borderline. I run E35 to be safe. I tried E45 and had fueling issues.
Car: 11 135i
Cool 02-24-2015, 12:50 PM
So 60% Ethanol is not the figure then? Does anyone know the figure? Roughly ? As per my first post have Fuel it stage 2 lpfp.
