Romel26 Romel26 is offline
Car: Mini F55 1.5L
Unhappy P0171 code after installing BMS intake - 09-07-2019, 06:55 AM
I got the P0171 code after installing ths BMS intake, is there anyway to solve this problem?
It's a mini cooper B38 2015
Thanks in advance
Default 09-07-2019, 11:25 AM
I think that is just a harmless MAF plausibility fault. Could try adjusting the MAF around a bit with washers or one side or the other to change the angle and see if that helps.
Tworons Tworons is offline
Car: Mini F56 JCW
Default 09-08-2019, 10:29 PM
I wouldn't run this code for long...Had it on a previous car, and although it did not affect performance, it played with fuel trims and lean conditions at the end.
Keep an eye on the LTFT and try to fix it.
