e92life e92life is offline
Car: e92 335i
Default High avg IGN of 6.7 - 93 oct? - 05-25-2019, 09:05 AM
335is 6MT, FBO + Inlets, STOCK intercooler. JB4 + MHD BEF I have a avg IGN of 6.7 on Map 2 and I'm on 93 oct and sometimes when I'm giving the car full throttle past 100 or so boost will cut off and it feels like I hit a brick wall but I WONT be thrown into map 4 or get ANY codes.
Could this be heat soak?
It's pretty much like an invisible limp mode. Never changed spark plugs/coil packs or done a walnut blast. I'll also hear the fans kick in at 100%. Thoughts?
Vorsprung_CJB's Avatar
Pessimistic Poster
Car: 135i N54
Default 05-25-2019, 10:16 AM
Generally you want to be at or under 5.0 on pump gas.
Could be heat soak or a combination, but given the bad avg_ign you might be totally bottoming out timing.
Without a log it is pure speculation.
Car: guess...
Default 05-25-2019, 03:42 PM
It's either air, fuel or spark.
Kindof sounds like fuel cut. Isn't map2 16-18 psi? I don't have MHD. Don't you need to choose your map according to oct fuel rating Variants (US OCT ACN91, 91, 93, 95 / RON 93, 95, 98, 102)? Try getting your fuel from a different station. Some are better than others.
If you've never changed spark plugs, you could easily be blowing out your spark with the higher pressures. They're pretty cheap online and a simple fix.
If you have a boost leak(massive), your DME target psi and actual could be way off.
Not to be dicky but do you know how to record a log with your JB4?
ManiN54's Avatar
ManiN54 ManiN54 is offline
Car: 2007 335i FBO stock turbos
Default 05-26-2019, 08:21 AM
Post logs for review, for some reason your timing flatlines. Your logs will show the reason.
Ps. That’s too much boost for pump gas.
1/4mile 11.8@117.96 19psi
07 E92 335i (the Alpträum) | Alpine wht/ Seibon carbon hood/ trunk| M parallel wheels| street tires
FBO| modified oem airbox lid w/K&N drop-in| stock turbos/ stock inlets| Walbro 465lph LPFP| Jb4/mhd backend flash| Map 6 w/E60 No Meth| Built and tuned by me.
