hilsman hilsman is offline
Car: bmw f90 comp
Default F90 JB4 Instalation - 05-23-2019, 07:51 PM
Help! Got my unit today and connected Bluetooth. Got confused when connecting the wastegate cables. It would seem the longer wastegate cable would connect to passenger side, however, it does not contain the extra black wire. The shorter cable does??? Fellow member stated Payam told him to connect the longer cable to passenger side though Terry’s instructions say that extra black wire cable (shorter) should connect to passenger wastegate.
Please advise. Would like to get completed this weekend. Thx
Default 05-24-2019, 09:48 AM
The EWG cables are roughly the same length from what I recall. Sure you placed the box on the driver side?
Car: bmw f90 comp
Default 05-24-2019, 09:56 AM
Yes, drivers side. The cable with extra black wire is clearly shorter. Others have also noted and therefore installed extra black wire cable to drivers side. Help
Default 05-24-2019, 11:14 AM
I'll update the install guide, sorry about that!
Your harness has a red wire on the longer EWG cable, that's the one that will go to the PASSENGER*** side.
Car: bmw f90 comp
Default 05-24-2019, 11:23 AM
Ok. Long cable to driver side. Shorter to passenger(with extra black wire). Correct??
Default 05-24-2019, 12:07 PM
Emailed you a picture, it was a bit too large to upload here.
Let me know if you didn't get it!
Car: bmw f90 comp
Default 05-25-2019, 08:13 AM
Ok for all novice diyers...the longer cable with the red wire goes to passenger wastegate. The shorter no red wire cable goes to drivers side ewg. Thx to all BMS support staff!
Default 05-28-2019, 11:51 AM
Thank you! I'll be updating the install guide soon!
