iturboh iturboh is offline
Car: E92 335i F30 328i
Default camshaft bearing ledges - 05-15-2019, 08:12 PM
anybody here ever have to replace their cam gear ledges? car isn't building boost and stuttering low rpm, read the codes with MHD and got there 2DEC, 2DED, 2DEB, 30FF, 3100, 29E1, 2A82, 2A87, 29CC, 29D0, 29D1, 29D2.
i cleaned the vanos solenoids, and put them back, car pulled good for like 3 pulls then same thing. Ordered some amazon ones, same thing, used a friends solenoids, same thing.
what should i check/do next, boost solenoid?
car is 2007 E92 with 100k miles.
kennejp's Avatar
kennejp kennejp is offline
Default 05-15-2019, 10:45 PM
What oil filter and oil? See this all the time and often is related to non oem oil filter or old oil.
07 E92 MT RB Turbos-600whp
08 E82 Built engine/trans Speedtech ST 6466
Car: 335i, 2009
Default 05-16-2019, 09:34 AM
For boost under target isn't that more of a boost system related issue? 30FF or 3100? Not sure on the other issues. And interesting to hear that oil quality, filter, and frequency of changes could be a factor.
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
Default 05-21-2019, 03:41 PM
I’m using the fcpeuro kit of liqui moly and mahle filter, although the very last time I used mobile 1.
So should I just do another oil first?
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 05-21-2019, 08:24 PM
Try Torco SR5 series , it’s the most expensive as it’s the best one !
Do more with less !
Car: 2003 Forester
Default 05-22-2019, 04:32 AM
Originally Posted by cebrailbakan
Try Torco SR5 series , itís the most expensive as itís the best one !
Lol yeah that's how it works....
turbotuning turbotuning is offline
Car: 2008 bmw 135i
Default 03-25-2020, 08:24 PM
n54 dp exhaust 3000 miles on oil running E30 mhd flash and im getting 2A87 3100 and also random other vanos codes im beginning to wonder if the ethanol is deluting my oil quicker than petrol and creating these problems this weekend I will change oil clean solenoids and see if it clears up my issues because I wasn't having them before E30 ive also tried other flashes Stage 1 Stage 2
