Haynpunch's Avatar
Car: 07 E90 335i
Default 05-25-2019, 12:09 AM
Did you check your Dash Menu 4/2?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
stellar1ca's Avatar
stellar1ca stellar1ca is offline
Car: 09 E90 335i
Default 05-25-2019, 01:22 AM
It was on 4/3.
'09 E90 335i
JB4/MHD BEF - High Flows - Custom Exhaust - FMIC - CP/Tial Q BOV- Hybrid Turbos - Silicone Relocated Inlets- Walbro 255
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-25-2019, 02:38 AM
Originally Posted by stellar1ca
It was on 4/3.
needs to be on 4/2 for BEF as noted in Dave's post
Did you relog after putting JB4 in 4/2?
07 E90 AT - xHP
FBO
Hybrids
stellar1ca's Avatar
Car: 09 E90 335i
Default 05-25-2019, 02:51 AM
Rgr, on the dyno now!
'09 E90 335i
stellar1ca's Avatar
Car: 09 E90 335i
Default 05-25-2019, 03:39 AM
Latest pulls and dyno results.
'09 E90 335i
Default 05-25-2019, 01:53 PM
Some timing issues / corrections- first log looked the cleanest imo
stellar1ca's Avatar
Car: 09 E90 335i
Default 05-25-2019, 06:15 PM
Are the timing issues related to the power loss between 3200-4500 RPMs?
'09 E90 335i
Raginge93 Raginge93 is offline
Car: 07 335i
Default 05-26-2019, 04:43 PM
You have a lot of timing issues. Fix that and youíre golden. I have almost the same mods and made 530whp/515tq on a dynojet @22psi
stellar1ca's Avatar
Car: 09 E90 335i
Default 05-26-2019, 04:51 PM
That's my goal. Thanks for your input!
'09 E90 335i
Default 05-27-2019, 08:55 AM
what fuel were you using on the dyno?
stellar1ca's Avatar
Car: 09 E90 335i
Default 05-27-2019, 03:24 PM
93 with octane booster. I'm using the pump BEF.
'09 E90 335i
stellar1ca's Avatar
Car: 09 E90 335i
Default 05-28-2019, 04:27 AM
I'm currently using the Bosch replacement plugs. Should I be using the NGK 97506 instead. I really want to eliminate my timing issue.
'09 E90 335i
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-04-2019, 09:34 PM
I reinstalled my OEM Vanos sensors. Additionally, I ordered NGK 97506 plugs and a 3.5 Bar TMAP in anticipation of solving my timing issues. Hoping to get my shipment before Saturday's dyno visit.
'09 E90 335i
Default 06-05-2019, 09:46 PM
Fingers crossed!
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-07-2019, 05:58 PM
My plugs and TMAP sensor made it! Gonna swap them and get some pulls in. Will post logs shortly.
'09 E90 335i
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-07-2019, 07:43 PM
Unable to change the plugs. I have to come back Monday.
'09 E90 335i
Default 06-08-2019, 10:49 PM
Take your time- have a nice weekend sir!
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-10-2019, 05:39 AM
Here are my logs from today's pulls. I'll send the dyno results once I resize the image.
'09 E90 335i
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-10-2019, 05:46 AM
Dyno results.
'09 E90 335i
Default 06-10-2019, 09:01 AM
Something is def off.
FF is maxed out.
Your way under target which would explain the low Dyno #s
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-11-2019, 04:21 PM
My last pulls were done on a Dynocom. There's a huge difference in the results compared to a Dynojet. Here are my steering wheel settings. Maybe something here is off.
speedo/tach
4/2
9/8
10/2.5
11/0
12/2.9
13/3.5
14/4.5
'09 E90 335i
Default 06-11-2019, 09:05 PM
speedo/tach
4/2
9/8
10/2.5
11/0
12/2.9
13/3.5
14/4.5
Donít think itís a settings issue
Based on your logs- you look to have a physical leak somewhere
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-11-2019, 09:11 PM
Not happy to hear but that gives me a starting point. Tgat explains the wastegate rattle!
'09 E90 335i
Default 06-11-2019, 09:12 PM
Yeah : /
stellar1ca's Avatar
Car: 09 E90 335i
Default 06-11-2019, 10:16 PM
I may have gotten lucky. I found a hose pushing my charge pipe away from the throttle body. Reseated the CP and the rattle is gone! I'll do some logging tomorrow.
'09 E90 335i
