Otto's Avatar
Otto Otto is offline
Car: 2010 BMW 335i
Default 05-17-2019, 10:45 AM
Im using a data link cable and my laptop does have usb
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-17-2019, 11:19 AM
Did you follow the instruction in the link I posted?
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Otto's Avatar
Car: 2010 BMW 335i
Default 05-17-2019, 12:01 PM
Those are the same links I originally used however I do remember when I first did it mine wasn't exactly the same as shown and computers are not my thing. Im going to erase all the downloads and start over tonight. Does the laptop need to be connected to the JB4 when downloading the software?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-17-2019, 12:19 PM
No not for downloading Firmware, Only needs be connected to Update firmware / Data Logging
07 E90 AT - xHP
FBO
Hybrids
Otto's Avatar
Car: 2010 BMW 335i
Default 05-17-2019, 03:30 PM
I uninstalled all the software from my laptop and started from scratch. This time I was very confident everything was done exact but still it won't connect. It says jb4 failed comm11. Speedo on menu 0 and rpm gauge on map 1.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-17-2019, 04:03 PM
I know it seems repetitive but did you double check that the usb comm port on PC is the same as set on the JB4?
Also did you make sure the data cable is connected tight to JB4?
07 E90 AT - xHP
FBO
Hybrids
Default 05-17-2019, 11:54 PM
Sounds like the wrong comport on the PC tbh
Otto's Avatar
Car: 2010 BMW 335i
Default 05-18-2019, 12:25 AM
My laptop has 3 USB ports and depending on which one I plug into it'll say comm10, 11 or 12. I've tried all three. I'll double check my data link cable to make sure the connection is good to jb4.
Default 05-18-2019, 10:40 PM
Sounds good
Otto's Avatar
Car: 2010 BMW 335i
Default 05-23-2019, 06:59 PM
Ok guys I decided to go ahead and get the Bluetooth. I gets here Saturday. So hopefully I can get some logs and see why she kicking me out of map 4. Then comes down ***** and a flash tune. I can't wait!
Default 05-24-2019, 12:35 AM
Otto's Avatar
Car: 2010 BMW 335i
Default 05-24-2019, 01:50 AM
Will the Bluetooth work with my iPhone8 or will I need an android?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-24-2019, 01:58 AM
you will need to purchase the JB4 app for either the IOS or Android, which every you choose to use.
07 E90 AT - xHP
FBO
Hybrids
Default 05-24-2019, 06:52 AM
Itís iphone compatible
available in App Store & google play if u decide u want a dedicated device
Otto's Avatar
Car: 2010 BMW 335i
Default 05-26-2019, 03:41 PM
Blutooth connected, working great! Very happy with it so far and created my first log. Now where and how do I send it.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-26-2019, 10:55 PM
Go advanced
Manage attachments
Upload file
Submit
07 E90 AT - xHP
FBO
Hybrids
Otto's Avatar
Car: 2010 BMW 335i
Default 05-26-2019, 11:46 PM
Go advanced
Manage attachments
Upload file
Submit
I don't see any of that on my app. I'm not using a laptop. I'm using my iPhone.
Default 05-27-2019, 08:49 AM
you still should be able to upload via your phone- may need to save the log to dropbox prior
Otto's Avatar
Car: 2010 BMW 335i
Default 05-27-2019, 11:19 AM
The log is saved but when I click on it I'm offered a graph box a email box a rename box and a preview box. So the only option it's giving me to share is through email. Is there an email I can send it to?
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-27-2019, 01:22 PM
Just need to remember where you saved the file when you click choose file
07 E90 AT - xHP
FBO
Hybrids
Otto's Avatar
Car: 2010 BMW 335i
Default 05-27-2019, 04:39 PM
I never got my laptop to connect to the jb4 so I ordered the Bluetooth. The Bluetooth connected fine and I was able to create a log but the log is saved on my iPhone.
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-27-2019, 04:59 PM
I don't use my iPhone for logging so i don't know exactly where the file is saved for iPhone, if you can figure out where iPhone stores the actual csv file then upload that file to this thread,
What i currently do is, i log using a Android Stereo so i just email that log to my iPhone and save that file to my iPhone in the files section (numbers) then i just load that csv file to a thread that i needed checked, you could just email the log to yourself and do it that way, unless someone that uses iPhone can chime in
07 E90 AT - xHP
FBO
Hybrids
Otto's Avatar
Car: 2010 BMW 335i
Default 05-27-2019, 05:04 PM
Thatís a good idea. Iíll try to email it to myself and see what happens.
Otto's Avatar
Car: 2010 BMW 335i
Default 05-27-2019, 08:43 PM
Don't know if this will work but here we go! If you can see the log is from 3rd gear WOT for about 4 to 5 seconds.
File Type: csv JB4.2019-05-26 18_12_51_Map-1.test.1.csv (25.2 KB, 18 views)
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-27-2019, 10:16 PM
Enable 6cyl timing logging
Need a log
Traction off Full throttle from 2k to redline
You went 100 from about 5k
07 E90 AT - xHP
FBO
Hybrids
