michael4702 michael4702 is offline
Default Target a boost (psi) - 02-07-2019, 03:24 PM
Hi all this maybe a silly question but can I target a psi?
I have an f10 m5.
Stock psi is 15 I think.
Map 1 is 19 psi.
Map 2 is 22 psi.
Map 3 is 18 psi ( I think)
I am getting clutch slip with map 1... which based on figures released by jb4 support... well map 1 is at the limits of the torque for the standard clutches. Based on 99 fuel I have... well I think I need a customer map....
Has any one targeted lower boost... jb4 said don't bother but I would still like to try... even 2 psi is worth 50 bhp
Thanks all
codesx codesx is offline
Default 02-08-2019, 10:48 AM
So, from what you write, you go up 4 PSI from stock and your clutch slips?
I don't personally know the f10 m5 specs, but that sounds off.
And you want to compensate by only moving it 2 PSI over stock PSI?
Sure, you can target boost with the JB4.
However, it seems like you really need to deal with the clutch if your numbers are correct. 2 PSI over stock just isn't worth the effort. You'll have to turn that to 1 PSI in a few weeks, then no extra boost, then under stock-boost.
Looks like fixing the car is the only lasting path.
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
Default 02-08-2019, 02:52 PM
Hi. Thanks for replying.
Map 1 on the m5 at 19 psi gives about 120 bhp... so even 1 psi is still worth it.....
So yes trying to setup 17 or 18 psi is still worth 75bhp...
I think map one on UK fuel 99 octane must make even more power... so map 1 is too much for the stock clutches... too much torque...
How do u target boost on the jb4? What may happen What it gets warmer
Many thanks
Default 02-08-2019, 06:27 PM
Post a log on map1 if you want us to check it out, shouldn't have any clutch slip on that I'd presume.
Default 02-09-2019, 09:33 AM
So I have wasted half a tank of fuel this morning and dialed map 6 in as attached (3rd attachment). Granted my clutches have done 57K miles and are 7 years old...
I am in the UK, I was using Shell super unleaded (99 Octane) and the temperature was 10c. I have installed 2 stage colder plugs and gaped to 0.022. The car is rock solid. I have upgraded the jb4 to the latest firmware.
With map 1, with 4th gear rolls on's from 35 mph to ***mph I was getting slip at 1.5 to 2K and 3.5K to 4.5K. So I tweaked the PSI (map 6) accordingly... I am now solid in 4th gear from 35mph to the red line, using map 6 (3rd attachment)...
If I used the gearbox (1st, 2nd 3rd, 4th) with map 1 I could minimize the slip, but it still slipped, I wanted it to be rock solid!
I also now have at least 10 "logs", I have attached a 4th gear pull in map 1 (. The log has two pulls, the first was no slip, the second (shortly after had slip... I guess the clutches heats up and bam, slip...
Any observations very welcome.
A good mornings work either way, as the car is faster... if not tamed somewhat compared to map 1...
Default 02-09-2019, 09:38 AM
Attached is the log for map 6, dialed in by me... just for reference :-) No slip!! This was a 4th gear roll on 35 mph to *** mph.
Default 02-09-2019, 11:39 AM
It's hard to tell if there is DCT slippage, it would normally look like RPM increasing faster than it should for the road speed and I don't see that?
Default 02-09-2019, 12:05 PM
Thanks for replying... I feel confident I have dialed it in for the time being..m. .ore power when I can afford 3k to upgrade the clutch...
I guess higher octane fuel will produce more power ? Also do u know what the st9ck psi is for each 500 rpm... that would be handy.
Default 02-09-2019, 01:14 PM
In your logs DME BT is the factory boost request, so easy to study logs and see how it moves around based on engine speed, weather, load, etc.
Default 02-09-2019, 01:37 PM
Thank you
Default 02-10-2019, 09:01 AM
Hi. I seem to be bogging a little from 3rd in to 4th... any ideas?? Many thanks
DaySleeper DaySleeper is offline
Car: 2001 and 2013 BMW M5
Default 02-14-2019, 06:23 AM
I think that happened to me also from 3rd to 4th. It takes a full second or two to shift. I run a lot more boost though with the meth injection around 25psi.
