HKD126 HKD126 is offline
Car: 2014 335i
Default Torqbyte/Prometh/BMS Methanol Injection Kit - Complete PLUG AND PLAY - 01-16-2019, 09:21 PM
Complete plug and play methanol injection kit for any BMW F30/F32. Only the highest quality parts were used. The wiring is already loomed for a complete seemless clean professional plug and play installation. There is plenty of length on every wire to make sure you don’t run out of length. The kit was only used for a couple of months as I just sold my car. I even made a walk through step by step instruction manual for installation and can be found here:
https://f30.bimmerpost.com/forums/sh....php?t=1530667
Parts included:
TorqByte CM5-LT
TorqByte BMW OBD plug adapter
TorqByte power cables/pump power cables
TorqByte Map Sensor (not used at all, but included)
TorqByte pump power pigtail (extra)
Littelfuse JCAS040.X - 40amp fuse
Littelfuse FHJC1001G fuse holder
BMS stealth tank
ProMeth 1.3GPM DDP 5800 pump
ProMeth 20’ 1/4 nylon tube
ProMeth 20psi check valve with 1/4” pushlock fittings
ProMeth 1/4" Hose to 3/8 NPT Male, Straight
ProMeth1/4" Hose to 3/8 NPT Male, Swivel Elbow
ProMethBillet Nozzle Holder With 1/4" Hose Fitting, Elbow 2 (2 for dual nozzle)
ProMeth 1/4" Hose Tee Fitting (for dual nozzle)
ProMeth 2gph nozzle
ProMeth 3gph nozzle
ProMeth 4gph nozzle
ProMeth 5gph nozzle
BMS EWG Harness
Pico 5593C relay
Blue Sea Systems in-line relay x 2
Blue Sea Systems 2 amp fuse x 2
I never got around to installing the EWG boost cut failsafe, but all the parts are included to do it. I travel for work and never had the time.
This kit made 414awhp/492awtq on a 2014 335i with simple bolt on’s and BM3 on an AWD dynojet.
I will not part out the kit as it is all packaged up ready to ship. Asking $750.
Car: 2014 335i
Default 02-05-2019, 12:06 AM
Bump
Car: 2014 335i
Default 05-04-2019, 12:52 AM
Bump
thnguyen89 thnguyen89 is offline
Default 05-20-2019, 05:38 AM
Will this fir 2010 135i n54?
Car: 2014 335i
Default 05-20-2019, 07:47 AM
You could certainly use everything for it, except the tank. You would have to double check the wiring though.
Car: 2014 335i
Default 05-31-2019, 06:16 AM
Price drop.
Showtime456's Avatar
Showtime456 Showtime456 is offline
Showtime456
Car: 2014 BMW 640 GC
Default 08-26-2019, 04:04 PM
bump..wanna just sell the controller?
Car: 2014 335i
Default 09-02-2019, 12:04 PM
Sold
