nyt nyt is offline
Car: 335ix
Default 11-30-2018, 11:41 AM
Originally Posted by v8bait
I'll make this even easier for your customers:
Adding cold-start by using your normal XDF, and the FF XDF:
1) Open your backend with the XDF for your DME version and modify "fuel (start)" to generally match the large table posted above, doesn't have to be identical (or copy/paste from attached xls sheet), save the .bin
2) Now, use the FlexFuel XDF available here https://github.com/dmacpro91/BMW-XDFs instead of the normal XDF, and modify the "warm-up enrichment factor" to match values above for the small table (again you may copy/paste from the xls sheet attached), save the .bin
3) Flash your new backend and profit by not being late when it gets chilly anymore because your car will now start perfectly every time.
4) Buy me a beer with all the extra money you will be making.
*NOTE* Do not change other tables using the FlexFuel XDF unless you know what you're doing, only change the "Warm-up enrichment factor".
Alternate method, adding tables to your normal XDF:
If you want to add the table to the normal XDF, I also attached a .txt with I8 and IJ addresses, add these to your XDF file and then you don't need to use the FF XDF to change the single table. If you want me to do all the work for you I will but I'll charge you something for it. Enjoy ya'll
ty!
2010 335ix - pure 600 turbos @ 30psi, dps, cp, 7.5in hd ic, inlets, outlets, jb4, pi, fuel-it stg3, at cooler
Default 11-30-2018, 11:44 AM
Thanks. I'll test these changes later today and add them to the E85 back end flash maps.
Default 11-30-2018, 12:22 PM
Originally Posted by chadillac2000
Thanks Justin! Looking forward to Terry throwing this coding in the BEFs so I can flash it up. These 20 degree mornings running full E85 have been rough.
Got it added so if you want to test just email me the name of your BEF and I can forward the right one for testing.
chadillac2000's Avatar
Car: 2008 535i
Default 11-30-2018, 12:29 PM
Sent!
narstune's Avatar
narstune narstune is offline
Car: '11 E90 335i
Default 11-30-2018, 12:33 PM
Thanks for sharing!
2017 M3 ZCP
Default 11-30-2018, 12:48 PM
Would be nice to get these tables in the S55 XDF... I don't think anyone has found them yet though?
Default 11-30-2018, 01:19 PM
I'll have to bring my 335i so we can reflash it
Car: 2008 535i
Default 12-03-2018, 08:57 AM
Loaded up the BEF with the updated tables earlier this morning. It was about 40 degrees this morning, so not the coldest of temps (yet) for testing, but fired up right up with no hesitation and no stumbles afterwards on E65 fuel.
Default 12-03-2018, 09:36 AM
Default 12-03-2018, 09:47 AM
For those who want to help test, I added the changes to the public IJE0S E85 maps:
12/03/18 Map Release
1) Added v8bait's cold start tables to all IJE0S E85 back end flash maps, should improve cold starts on E85 fuels. If all goes well we will port the same changes over to the other ECU versions.
2) Various tuning changes, new maps added, etc.
Default 12-03-2018, 10:07 AM
Now if I can only get that for my M4 lol.
Default 12-03-2018, 10:14 AM
I know we need the S55 tables for these. I'll go harass Martial.
BOosted 335i's Avatar
BOosted 335i BOosted 335i is offline
Meth Addict
Car: E90 TiAG 335i Sedan
Default 12-03-2018, 06:22 PM
i Have IJE0S and run his tune with cold start and has been good,no hesitation or stumble,if that helps.
E90 335i Auto, Cold Weather, & Sports Prem. Package, Navigation
Mods
: JB4/MHD, ACF ST, Precision T/S 6062, AD-Eng Mounts, Precision RaceWorks Stg 3+LPFP, //HPF Exhaust Titanium Tips, Custom HighLow OCC, Precision RaceWorks Coils,RACE InterCooler, Custom Meth Kit, Justin(v8Bait)Tuning
Car: 2008 535i
Default 12-04-2018, 08:23 AM
Excellent work.
Default 12-04-2018, 12:55 PM
Wow, that's pretty awesome!
Aaron Aaron is offline
Car: 335is
Default 12-04-2018, 02:40 PM
There doesn't need to be any more testing. We finished all that a year ago. You guys should pay the man for the immense amount of time and energy he put into this when no other tuners could touch it.
https://youtu.be/aCcujsRFE7g
https://youtu.be/wtwPehLY4d4
https://youtu.be/mr1YRRLYP28
Car: 2008 535i
Default 12-05-2018, 09:32 AM
Yeah, I'd say this is a wrap. With a dusting of snow on the bonnet, and a temperature of 25 degrees this morning on E65 -- results were identical to yesterday that I posted up.
V8Bait, thanks again! You've made my mornings just a little bit easier.
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 12-05-2018, 12:33 PM
I find it takes about 30-45 min for my wastegate to warm up enough to not stick and overboost me on even the lightest of throttle!
v8bait's Avatar
v8bait v8bait is offline
Car: E92 335i 6MT
Default 12-06-2018, 06:31 PM
Yeah, when you go outside in sub zero temps and your car doesn't start on full e85, forcing you to ride the Huffy to work in the snow, you do reconsider the race car lifestyle. You might even consider things like "pump gas". Luckily for you that will no longer be the case and your life can now be enriched by more important things, like sitting in traffic from the accidents on frozen roads, and having no excuses for why you're late getting home to your wife.
Cheers
FEDE/E92 FEDE/E92 is offline
Default 05-04-2019, 12:57 PM
Has there e85 cold start tables been added to all computers
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 05-15-2019, 07:06 PM
No issues with cold start here, F80Paul Custom Tuned on BM3 I started up even in 11F in winter Full E85
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 05-16-2019, 01:15 PM
hmm oddly i only have e85 stumbles when its hot lol
2009 335i e92 n54 | FBO | JB4 | e85 flash |
