(#326)
Default 05-19-2019, 06:39 AM
Originally Posted by FeldiSan
Hello,
I have not seen this error yet. I drive with the JB4 anytime and have no problems since I bought them.
I do not have an engine control lamp in the Driver Info Display. Not that the chain jumped ?! Is it for me as a borrow to control? Feels like the engine is running normally without noises or loss of power.
Greetings from Germany
Micha
Clear the fault and see if you get it again.
If the chain jumped you would know about it. Its not something this serious though.
brat boy's Avatar
brat boy brat boy is offline
Car: VW Golf VII GTI
Default 05-19-2019, 08:58 AM
Latest VW JB4 firmware attached.
JB4_VW_8_4
1) Adjusted boost by gear sensitivity so it won't engage under lower throttle positions.
VW_JB4_OBDII_8_T3
1) Boost control per gear capability of lower than ECU/Flash target
2) Boost target can now be set lower than ECU/Flash target
VW_JB4_OBDII_7_TEST4
1) Part throttle changes for smoother power delivery
2) Map 4 to valet map
3) Webasto and other auto warm systems triggering alarm resolved
VW_JB4_OBDII_6B:
1) Revised fuel mapping for improved drivability and performance.
Hi
I am new to this, do I load each of these onto the box or does JB4_VW_8_4 have the others in already?
Default 05-19-2019, 09:06 AM
Originally Posted by brat boy
Hi
You don't need to load them all in sequence. Each version over writes what is on already and includes previous version updates.
brat boy's Avatar
Default 05-19-2019, 11:48 AM
cool so will just load 8_4. Thanks George. I also sent you a mail. I am Form South Africa. I am awaiting the cable.
Obviously Obviously is offline
Car: 2017 Audi S3 Sportback
Default 05-23-2019, 03:14 AM
Only the 7R and S3 are affected. They do a type of misfire on the gearshift when launch control is used. We use map 6 to taper the boost closer to stock on those and it runs clean.
Hi George, I’m Johannesburg-based with a 2017 8V.2 7-speed S3 and now with the latest firmware and use launch control but don’t think I’ve experienced the misfire you mentioned? I do not have an hardware mods and have always been on Map 1. Is this only a Map 6 issue? What I have noticed at times however, is that the car sometimes “gags” at low speed in first gear in traffic, during part throttle applications. Almost like a split second of no power before it comes in. It also sometimes seems to momentarily hesitate prior to full throttle demands on the highway - perhaps more noticeable when switching from Efficiency to Dynamic mode at the same time and perhaps more so after an extended period of slow/conservative city driving.
Default 05-23-2019, 06:03 AM
Originally Posted by Obviously
Hi George, Iím Johannesburg-based with a 2017 8V.2 7-speed S3 and now with the latest firmware and use launch control but donít think Iíve experienced the misfire you mentioned? I do not have an hardware mods and have always been on Map 1. Is this only a Map 6 issue? What I have noticed at times however, is that the car sometimes ďgagsĒ at low speed in first gear in traffic, during part throttle applications. Almost like a split second of no power before it comes in. It also sometimes seems to momentarily hesitate prior to full throttle demands on the highway - perhaps more noticeable when switching from Efficiency to Dynamic mode at the same time and perhaps more so after an extended period of slow/conservative city driving.
The hesitation on light throttle is more a DSG thing if it changes based on mode. What happens is the DSG plans to shift up and then you give it a bit of gas and it decides to stay in the same gear causing a pause.
At altitude we haven't had issue with the 7 speed. Most likely due to slight variance in boost achieved so its not a concern.
Default 05-23-2019, 06:18 AM
Thanks George. Yeah, LC works like a charm, with the car easily breaking traction when launching from 4K. Interestingly, Iíve had no issues launching the car when on holiday down at the coast as well? Just that the car feels far more responsive down there. What would cause that momentary hesitation on the highway during kickdown though?
steel234's Avatar
steel234 steel234 is offline
Car: S4 B9
Default 05-25-2019, 03:48 AM
Hi guys,
my friend bought a new Seat Leon Cupra SW 4x4 (2019) and asked me for a piggytail.
Of cource JB4
But he has a new Cupra, with DSG7 and gasoline particulate filter.
Will it works with last firmware of JB4? Has it anyone in 2019 Cupra, will it works without problems?
Thx, Nick
8W5 CWGD ||@BMS
5F CJSA || Full Stock
A/H Z18XER || @EDS
"What we dealing with here is a total lack of respect to the law" (c) TP 1994
Default 05-25-2019, 03:35 PM
Originally Posted by steel234
Hi guys,
Of cource JB4
Thx, Nick
No issues with the GPF Cupra. We have done quite a few of them already. No specific firmware is needed.
JuanFranCupra JuanFranCupra is offline
Car: Seat Leon Cupra 2019
Default 05-26-2019, 12:14 PM
Hi guys,
Of cource JB4
Thx, Nick
Yes, I confirm that it works well. I have a cupra 2019 with GPF
In my cupra with map 2 I need to set the PSI Boost Failsafe to 27 because in 25 it sometimes goes to the map4.
I have also set Auto Shif Boost Redux at 65 because if I keep it off when it switches from fourth to fifth gear the blows exceed 27 psi and it seems too much
Use 98 octane gasoline, is the maximum we can get in Spain
sirfredi's Avatar
sirfredi sirfredi is offline
Default 05-27-2019, 07:40 AM
the jb4 has Doownpipes fix? I'm thinking about installing some D0ownpipes but I would not like to have a fault
Can someone give information about this?
Chris1981 Chris1981 is offline
Car: Cupra 300 4drive with GPF
Default 05-29-2019, 12:54 AM
Thank you, had some bad issues with MAP2, with your Settings itís working fine!
Without this settings, the car gets problems (4drive 300 with GPF fuel 100 octane) with Speed over 200km/h, loosing boost, switching to map4 and EPC light on.
Pulls much better now when shifting... and feels much better...
Log looks good.
steel234's Avatar
Car: S4 B9
Default 05-29-2019, 01:12 AM
thank you guys, looks good!
8W5 CWGD ||@BMS
A/H Z18XER || @EDS
julian2292 julian2292 is offline
Car: bmw 1m
Default 05-29-2019, 01:08 PM
Hi.
Why 65 on auto shift boost redux. I thought that were values of 0 or 100. 65 what does or means.
Default 05-29-2019, 02:04 PM
Originally Posted by julian2292
Hi.
The value cuts the boost during the shift. The higher the value the more cut there is. There is a point if you increase it too much it can be felt if its not used to control a present issue.
_Dejan_ _Dejan_ is offline
Car: Seat Cupra ST 300 4DRIVE DSG
Default 05-29-2019, 11:16 PM
I have also Cupra 300 ST 4DRIVE&DSG 2018(Without GPF) and need run boost limit 28 and still sometime get CEL and car go to MAP4...
Im try setup boost redux to 80,100 and do not help to avoid spike of boost after gear change...
Boost redux 80:
Boost redux 100:
In last picture I accelerate in 4th gear and in 4th gear max boost is 22,1psi(ECU is max 16.5psi) then imediately after gear change to 5th gear and continue acceleration it spike to 28.2psi. BUT I know that main problem is not JB4 because ECU in that time request 23psi and don't know why this is happen but don't like it...
Default 05-30-2019, 08:15 AM
Boost redux 80:
Lower the boost add from 6000 and higher and it will clean it up. Use something like this:
5500 6
6000 4
6500 2
7000 2
Default 05-30-2019, 10:24 AM
I will try. Today Im try after long time push car harder and get issue in 5th gear.
Im start in 3th gear and then in 5th gear after gear change is car normaly pull but few seconds later it lose power and JB4 is change to map 4(Boost is over 28,1 for too long). Log is in attachment. Im also upload it on datazap:
https:// datazap . me /u/dejan/jb4-map6-fol45-maxpsi-28-boost-redux-65-30052019-boost-issue?log=0&data=1-4
Do you maybe know why ECU request that high boost?
At 5500rpm in 3th gear ECU request 15.1psi
At 5500rpm in 4th gear ECU request 19.4psi
At 5500rpm in 5th gear ECU request 21.7psi
Also ECU half close throttle after gear change to 5th gear.
I will in next days test it on map 0 to see if this strange behavior will still be present...
quattromaniac quattromaniac is offline
Car: 2018 Audi S3
Default 06-05-2019, 10:14 PM
Anyone have map 6 settings that's between map 1 and 2 for Audi S3? Is there a way to improve the low torque between 1500 - 4000rpm? Thanks!
Default 06-15-2019, 05:42 AM
For guys with the idle hiccup see if this firmware irons it out. Been sending it out to individuals for the past week and it seems to be eliminated with smoother spool up as well.
Let me know your findings.
Once we happy with the results we will add new maps to this and post it in post 1.
dgraham1284 dgraham1284 is offline
Car: B9 A4
Default 06-15-2019, 01:59 PM
Never had an issue with idling. However, the turbo spools noticeably smoother now. Solid firmware that pulls hard with a peak boost of 6.0 psi additive.
blackgti blackgti is offline
Car: M235I
Default 06-15-2019, 04:59 PM
I just installed a ******** and I’m running Map 2 on 93 octane. I threw a P0100 code after about 10 miles of driving and I wasn’t sure if it is related to the JB4 or not. I have a 2019 Golf R if it makes a difference.
Car: B9 A4
Default 06-15-2019, 07:11 PM
Originally Posted by blackgti
I just installed a ******** and Iím running Map 2 on 93 octane. I threw a P0100 code after about 10 miles of driving and I wasnít sure if it is related to the JB4 or not. I have a 2019 Golf R if it makes a difference.
Checked the air filter to make sure it's clean?
Default 06-16-2019, 08:37 AM
Yes George!
I just tried it in my leon cupra 2019 and it works fine.
The feeling of unstable idle has disappeared!
It seems that everything it is OK!
Default 06-16-2019, 09:22 AM
Yes George!
Thanks for the feedback
