Roxxor Roxxor is offline
Car: 2013 328i M-Sport
Default Adding DP to N20 w/ EWG and JB4 - 09-05-2015, 03:05 PM
Hi all,
Finally bit the bullet and ordered a DP for my N20, it was a late model 2013 with the EWG. Been running JB4 on Map 1 with no issues so far, and always use 93 octane. I have not ordered/added the EWG wires, as I read mixed reviews about any gains from it. Of course, now that I ordered the DP, I am seeing all kinds of issues popping up about the N20 reliability at higher boost levels. So, my questions are:
1. Is it within the realm of safety to still use Map 1 after installing the DP? Will there not be any noticeable gains, or do I need to use Map 2 because of the DP?
2. Since I will not be using anything other than Map 1(or possibly Map 2), are the EWG wires a necessity since I am adding the DP? Also, if I am not using the EWG wires, would the EWG firmware be of any benefit or should I leave it the same?
Thanks for any insight, just looking to give the car a little pep in her step without going overboard(or damaging anything serious )
LycanX4M40i LycanX4M40i is offline
Registered Users
Car: 14' F25 X3 xDrive28 M-Sport AlpineWhite DHP
Default 09-06-2015, 01:16 PM
I also hear DP show barely any gains on N20
But a lot of things have to be taken in consideration..
93+ octane
RWD or AWD ?
AT or MT
Location
Default 09-06-2015, 01:35 PM
93+ octane
RWD or AWD ?
AT or MT
Location
Yeah, just realized I mentioned engine but much else.
2013 328i RWD AT, located in Florida. Always use 93 octane
LoveTwenty LoveTwenty is offline
Car: F30 320i
Default 09-13-2015, 01:50 AM
Originally Posted by Roxxor
Hi all,
If your vehicle has EWG actuator, then you should use EWG firmware.
It depends on your wastegate actuator type, NOT connecting EWG connector.
If you only use map1 and map2, then dont need to connect ewg connector in latest firmware.(I mean if your jb4's map1 and map2 are additive maps)
because in map1 and map2, ewg signal will be ignored.
Registered Users
Default 11-07-2015, 06:33 PM
Did DP show any gains?
