(#476)
Default 05-07-2019, 07:47 PM
High pressure fuel pump can't really sustain it on the Raptor. On the 2.7L though should be possible but we'd need a back end flash as well to go along with the JB4.
DB119 DB119 is offline
Car: 2017 Ford Raptor
Default 05-21-2019, 01:01 PM
Size:  105.0 KB. Hey Terry. Could you take a look at this and tell me if the numbers look ok. 2017 Raptor jb4 map 5 on Lucas additive + 93 octane. Wot. Thanks ia
Default 05-21-2019, 04:14 PM
Attach the CSV so I can scroll through everything in the JB4 interface!
Default 05-21-2019, 05:55 PM
Iíve been trying and canít seem to figure out how to attach... ??
Default 05-22-2019, 10:18 AM
Go to advanced, and click the paperclip icon. Then a pop up will come up for you to upload your attachments/files.
FirstBMWLA FirstBMWLA is offline
Default 05-23-2019, 11:34 AM
Does JB4 monitor OBD readiness?
Can it tweak throttle mapping or do you have to run the pedal tuner as well?
Default 05-26-2019, 02:07 PM
No we don't monitor it. Could add that option if needed but normally a basic OBDII scan tool is used for that when needed.
For the sort of dynamic pedal mapping I think you're referring to get our pedal tuner. The JB4 maps do adjust pedal to boost target but it's not quite as dramatic.
20182.7f150 20182.7f150 is offline
Car: 2018 Ford F150 2.7t
Default 06-04-2019, 03:54 PM
Hi Terry. Can you please take a look at my attached log? 2018 F150 2.7 turbo. Also, why don't I have a reading for high pressure fuel? Altitude: 5,280 ft. 91 octane.
Default 06-04-2019, 06:09 PM
Grab the v6 firmware in the first post and grab a log so we can see if you get fuel pressure with it.
Default 06-04-2019, 08:00 PM
Here you go Terry. Accidentally picked map 3 but we are getting fuel now. Is 15 the % duty cycle?
Default 06-04-2019, 10:10 PM
Good... It's 15mpa, or around 2250psi.
Default 06-05-2019, 05:36 AM
Thanks! How does everything else look?
Also, what's Max MPA on the 2.7 Ecoboost application? Trying to figure out how much ethanol I can run.
Default 06-05-2019, 02:16 PM
Seems fine to me so far.
You'll run out of fuel trim before you run out of fuel pressure... I run 30% on our 2.7L truck without issue so start there.
jamesatl335is jamesatl335is is offline
Car: 2012 335is Conv.
Default 06-08-2019, 09:08 AM
New firmware map 3...boost is over 4; closer to 5.25. Not sure this is by design.
Any how, how does the log look?
2018 Navigator
Latest firmware on map 3https://www.dropbox.com/s/jjqd4vat5b...Map-3.csv?dl=0
93 oct
12' 335IS Convertible (w\DCT)--BMS DCI--G5 ISO--E85\93 Mix
Default 06-08-2019, 06:02 PM
Looks fine to me!
red3171 red3171 is offline
Car: 2018 Ford F150 2.7EB
Default 06-08-2019, 09:13 PM
Terry,
Do you have any map 1, 91 octane, HP/TQ numbers for the CARB version for the 2015+ F150 2.7EB?
Esquire Esquire is offline
Car: 2019 F150 Raptor
Default 06-09-2019, 01:55 PM
Can someone check out this log for me? 2019 Raptor, Map 3 on 93 octane. Thanks!
Default 06-09-2019, 09:30 PM
It's dropping to map 0 as boost safety is set low at 22psi. Raise that to 25psi.
Originally Posted by red3171
Terry,
From our site:
2.7Boosted-Brad's Avatar
2.7Boosted-Brad 2.7Boosted-Brad is offline
Car: 2018 F-150 2.7
Default 06-10-2019, 12:13 PM
Any idea when full e85 map/backend flash will be available?
Default 06-10-2019, 03:45 PM
We've sent maps out to people who have flashed with HP tuners. With HP Tuners you have to port the changes over to your software version though, so its generally suggested for those familiar with HP Tuners and tuning in general.
Default 06-11-2019, 12:01 AM
From our site:
I saw that and was thinking the California numbers would be lower.
Thanks,
Red
Default 06-11-2019, 09:08 AM
We're located in CA.
Default 06-11-2019, 11:12 AM
Terry,
What are the main differences of a CARB compliant version of the JB4 compared to the others?
Thanks,
Red
Default 06-11-2019, 03:10 PM
CARB systems have a fixed firmware that can't be updated, and is the only system legal for sale and use in California. The tuning is all the same as are the connections.
