cabby cabby is offline
Default Zusb loose for DCT, N55, 2010, E93 German - 05-14-2019, 09:11 AM
Hello Guys,
I've loose my oem zusb after change the DCT!
Is there a possibility to finde out the old OEM-Zusb from DCT?
I would like to flash the OEM-Zusb again and then the IS-Flash.
Or is that unneseccary?
My Hardwarenumber is: 8606066 (I don't no it's correctly?)
My Zusb: 8606074
I've found it in GK40 Datens.
And one more Question: after flash with winkfpt, is it neseccary to write a new *.man with NCS?
Thanks a lot for help and with the best
Cabby
Default 05-15-2019, 12:59 AM
Has no one a tip?
Car: 2011 N55 135DCT
Default 05-16-2019, 06:18 AM
No u dnt need blank man
Default 05-22-2019, 10:12 AM
Hello Jacques,
I didn't understood?
Have you a litle bit time for help?
That would great!
Unfortunately I dont know the right zusb's!
With the best
Cabby
keyap keyap is offline
Car: N55 135i
Default 05-26-2019, 10:26 AM
Try reading UIF to get a list of Zusbs.
From memory, WinKPF will give you current and historic.
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | Berk Race Full Exhaust | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
