General.Massacre General.Massacre is offline
Car: 2009 E92 335i DCT
Default Jb4 Menu 4/4 - 05-19-2019, 04:38 AM
Hi all.
So I've reading a lot of threads. But a little inconclusive.
I am considering using JB4 with Menu 4/4 for full flash and to be able to utilise the Methanol System
I know you can place the white sub connector back to stock to have the Car run boost via the Flash.
And keep the JB4 Subconnector connected to have JB4 control boost.
I read that I can use any map as long as it's not Map0. Is this count for white subconnector connected or disconnected?
And will Map 3, 6 or 7 still control meth?
Thanks in advance to everyone.
Hope to hear soon.
Justin
Default 05-19-2019, 10:13 AM
There are lots of ways to do it, just depends on what you're trying to do. If you just want meth to be mapped out but with no safety systems or tuning at all then that is how you'd do it. Mode 4/4 white subconnector disconnected.
A better implementation would be mode 4/3 and map3 for WMI using a variable additive to determine boost target under full meth flow. You'll never target below the flash target then but will go over it based on additive when WMI is properly flowing.
The best implementation is 4/2 and map3. But like I said, there are lots of options and the devil is in the details.
Default 05-19-2019, 10:41 AM
Haha wow making it even more confusing.
So you saying I can use full flash also on 4/3 also?
I know 4/2 is BEF mode only. But there is alot of options here and searching it all is limiting.
I'd like to use Meth with JB4 and utilise a full flash map and test it back to back with the BEF option.
Keeping as many safety options as possible.
Looking to learn as most I can with this and get better knowledge like you guys have.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 05-20-2019, 11:59 AM
Does the Op understand that a back end flash does about 99% of what a full flash does but let's the JB4 decide boost targets with added safeties?
Default 05-21-2019, 03:52 AM
With the JB4 disabled / full flash- imo that’s what you miss, the safety aspect.
Default 05-21-2019, 05:55 AM
Hi AWSAWS,
I do understand what the Back End Flash provides. was just interested in the JB4's full range of features.
I do like the safety aspect,
Im currently driving without the BEF at the moment and menu 4/3.
Will be loading the BEF back on the car soon as i can as i am travelling.
I think i felt the DCT clutch slip this morning on a map3 pull for a log, and thats very concerning for me.
AWSAWS's Avatar
Default 05-23-2019, 11:36 AM
Originally Posted by General.Massacre
Hi AWSAWS,
You need to run a flash/back end flash with raised reported torque as the tcu determines clutch clamping force from that. It will prevent slippage and accelerated wear.
Default 05-25-2019, 03:47 AM
I assume this would be via Custom Flash.
Which is on my to do list.
thanks you for that little gem.
