Dannyzack99 Dannyzack99 is offline
Car: 09 335xi FBO
Default More PSI on Vargas Upgraded OEM-Size Turbos - 05-11-2019, 09:36 PM
Iím FBO + inlets & outlets with Vargas OEM-sized Turbos but they have the upgraded TD04 internals, upgraded wastegate, and the upgraded billet compressor wheel. My question is what psi can I safely max these turbos out at? Because the 17 psi on the backend flash in map 2 doesnít seem like enough. I ordered the 3.5bar TMAP sensor. Whatís the max psi you guys are running on stock turbos to give me a rough idea?
THE BEAST's Avatar
Car: 2008 E93
Default 05-11-2019, 11:24 PM
Shouldnt you be asking the vendor since they know what they did to those turbos ? They are NOT stock so why try and compare ????
Haynpunch's Avatar
Car: 07 E90 335i
Default 05-11-2019, 11:44 PM
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
treehouse treehouse is offline
Default 05-13-2019, 09:05 AM
You should really let the logging tell you where your limits are. There are too many variables to say a blanket statement like you should be able to run 20PSI with X turbo. Start at map 1 and then work with a tuner or do the research to tune it safely. Shouldn't take long to get it dialed in.
codesx codesx is offline
Default 05-13-2019, 09:40 AM
Mic dropped.
n54tech community walks of stage.
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
2019 - Index 12 Injectors | VCG | OFHG & O-rings | Alternator w/ Clutch Pulley | Water Pump & TStat
kennejp's Avatar
kennejp kennejp is offline
Default 05-15-2019, 10:55 PM
Like people have said, I think your logs will let you know when your running out of fuel/timing doesnt look good. Remember 17 psi stock turbos fbo is a lot different then upgraded turbos on 17 psi(moving more air). Post logs and the community will help guide you. You can also have a tuner do a custom backend flash that will help you with the process.
Side note for reference, I had a customer dyno at 470ish whp at 20 psi fbo stock turbos and then just redynod with mmp stage 3 turbos/inlets/manfold(everything else the same) at 22psi and made 605whp with the same tuner
07 E92 MT RB Turbos-600whp
08 E82 Built engine/trans Speedtech ST 6466
Torgus Torgus is offline
Car: 335xi
Default 05-22-2019, 01:36 PM
Ask your tuna
VTT should be able to tell you what they made on what fuel to give you an idea. I would assume they dyno'ed their own product.
Got Boost?
