F30.stl F30.stl is offline
Car: Bmw 320
Default Cant Hit Target boost - 12-04-2020, 06:24 PM
cant hit target boost just installed jb4, not familiar with it. i am using map 5 and newest update, and sometime it would switch me to map 5.
Default 12-07-2020, 02:08 PM
Are you using an EWG connector? If not that is required with a 320i to hit the higher targets!
Car: Bmw 320
Default 12-07-2020, 02:29 PM
No i do not i just ordered it Saturday night should be in mail sometime this week.
Once arrives gotta just install the connector and use the same user adjustment setting that a screen shot and i should be good to go.
Default 12-10-2020, 02:31 PM
Yes, log like that, then we can evaluate to make sure it's tuned up properly!
Car: Bmw 320
Default 12-16-2020, 04:02 PM
Installed the ewg. I attached two logs one with ff50 and one with ff100
Default 12-18-2020, 10:05 AM
Try FF = 75 next, but seems boost is up now.
Car: Bmw 320
Default 12-18-2020, 02:34 PM
The that connector definitely did the trick.
Default 12-18-2020, 03:37 PM
The really low DMEBT due to cold weather is throwing the scaling off a bit. For kicks let me see a log on map2 which is an additive map for comparison.
Car: Bmw 320
Default 12-20-2020, 03:37 PM
I left all the user adjustment same i dint touch them. Map 5 feels way stronger
Default 12-20-2020, 06:17 PM
Yes I can see, although this log looks cleaner!
I have an idea on the firmware that may help you. Email me the map5 log as a reminder to terry@burgertuning.com.
