Bluesz_ Bluesz_ is offline
Car: '10 535i xDrive
Unhappy 2Step/NLS - 09-16-2019, 08:56 PM
Hey Guys/Gals
Installed the 2Step/NLS w/ Antilag but it doesn't seem to work correctly.
When I try to 2 step w/ volume down it does cut the ignition and limit the revs to whatever I set it too. It sounds like it cuts ignition back fires. JB4 Mobile app tells me I'm making about 1lbs of boost only and also the loud backfired and bangs does not happen no matter how long I 2 step for. I've tried all the rev ranges from 2k to 3k and every single time I don't backfire or build much boost. I'm currently on Map 5 w/ BEF of Pump_USA Map Template via MHD. My NLS doesn't seem to work either. Holding the volume button down doesn't cut ignition with the clutch in. I just end up revving my engine.
I've attached pictures of my settings so maybe someone could assist.
Thanks in advance!
Default 09-17-2019, 09:35 PM
Bump..
TdotN54 TdotN54 is offline
Car: 2008 335i
Default 09-18-2019, 03:19 AM
Same issue here! Hope we both find a solution.
Default 09-19-2019, 08:24 PM
We in this together...
Default 09-19-2019, 08:25 PM
To add into my problems on Post #1.
I've added a datalog of 2step/antilag and just 2step.
Maybe a log could assist the issue.
Default 09-20-2019, 07:39 AM
Just to confirm- have you gone over your install?
How old is your JB4?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 09-20-2019, 07:42 AM
My install looks correct, via guidelines of the install guide.
Not sure I bought mine preowned. Is there a way to check?
Default 09-20-2019, 10:28 AM
Open up JB4 / check out board.
Most new / used are relatively new, but before we go nuts- let's see what we are working w.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 09-23-2019, 10:05 PM
Sorry for the late response, due to work hours i been just working and sleeping.
Iíve attached a picture for you.
