ac_schnitzel ac_schnitzel is offline
Car: 2010 535i
Default PI or HPFP overdrive on pump gas only? - 12-12-2021, 01:00 PM
Trying to decide fueling set up if my goals are between 500-600whp with upgraded twins.
Pros/cons?
May eventually run some e blends but would mostly use 91
desmo900 desmo900 is offline
Car: 2008 BMW 135i
Default 12-15-2021, 07:53 PM
I don't believe you can get 600hp on 91, I think 550hp would be a stretch as well.
Dave @ BMS's Avatar
Dave @ BMS Dave @ BMS is offline
Default 12-26-2021, 09:20 AM
500 HP on 91 octane / upgraded twins isn't something I would really suggest.
For your power goals, you don't need either honestly. Depending on the hybrid turbos & E30/40 with a healthy HPFP / Upgraded LPFP can easily make 500-600.
Car: 2010 535i
Default 12-26-2021, 11:15 AM
Thanks Dave! Do you have an unbiased opinion on the best hybrids for N54 for longevity and reliability at those goals?
Car: 2008 E93
Default 12-26-2021, 02:44 PM
Pure stage 2
Dave @ BMS's Avatar
Default 12-26-2021, 06:46 PM
I like the Pure Stage 2 Hi Flo
And any of the RB Stage 2 or larger options would fit the bill.
*I will add it's been like 1-2 years since I've looked into hybrids, there seems to be a ton more brands than prior, I would email Pure & RB and talk to them about goals / options- it's a pretty expensive upgrade, support is always important
gyhujbox5 gyhujbox5 is offline
Car: renualt
Default 12-30-2021, 07:24 AM
I don't believe you can get 600hp on 91, I think 550hp would be a stretch as well.VidMate Mobdro
