(#101)
Default 06-06-2022, 09:44 AM
Originally Posted by djpapeleta360
Hi. I just installed Jb4 and running map 2 on my G83. When launching I get tons of wheel spin on Michelin Sports tires. Attached are my logs. I was running firmware 46/5/5 at the time. I downloaded the latest firmware and have not gone on another run.
Are you RWD? What fuel are you running?
I would lower FF to 40
And maybe put boost by gear value 3 in 1st gear, that might help.
djpapeleta360 djpapeleta360 is offline
Car: BMW G83
Default 06-06-2022, 09:58 AM
Im on xdrive running default stage 2 map. Can the default maps be adjusted?
Default 06-22-2022, 08:39 PM
Try setting 1st gear to 3psi in the app to reduce boost off the line!
riverracer55 riverracer55 is offline
Car: 2022 X3M
Default 2022 X3 S58 Map 2 log - 06-25-2022, 02:11 PM
Sorry for only 1 log. I actually recorded 2 logs per map, map2, map3, map4, and map 5. All done on a pump/race gas/ethanol blend coming out to about e32-33 97-98 octane. Sadly this is the only log that is saved. If you could please take a look and I will update my app to do more logs once I fill the tank with the good stuff again.
Also, BC button for exhaust flaps seems not to work. Any help would be great.
goldfz8's Avatar
goldfz8 goldfz8 is offline
Car: BMW 135, Yamaha fz8
Default 06-29-2022, 09:52 PM
What map would you use for say 110 Octane?
502whp 593wtq
11.995 @122.08. 60' 2.041
3180lbs w/o driver
Default 07-01-2022, 02:36 PM
Avoided loaded fuel, but map5 generally for MS109.
Default 07-28-2022, 09:24 AM
Some S58 port injection dyno testing underway... It's a sweet kit, you guys are going to love it.
phaser's Avatar
phaser phaser is offline
Car: X5 M50i
Default 07-29-2022, 01:21 PM
Amazing numbers Terry.
What are you guys doing here in your testing?
EMC EMC is offline
Car: 335d
Default 07-29-2022, 02:52 PM
Any other changes needed to the fuel system hardware other than the PI kit?
When is the expected release date?
2022 M3xdrive
Default 08-04-2022, 07:28 AM
Any day now for release.
No additional changes needed, we're running the factory low pressure pump right now on ours.
Default 08-04-2022, 07:29 AM
The X4 has our JB4, prototype intake, Fuel-IT port injection, exhaust, and the DME is unlocked so we can do MHD back end flash development.
Sleepys4 Sleepys4 is offline
Car: 2020 c43
Default 08-05-2022, 03:43 PM
Someone finally cracked the ECUs stateside!?
