Originally Posted by TURBINA
Hi George!
I understand. My main doubt is if I can configure the fuel for 100% Ethanol, because I'm about to buy the JB4 but I don't know if it will work. or if it is possible to change the percentage on the map.
About the turbine, no problems, I'm already running it on the original engine and it works well, but with low performance. I've already seen that the JB4 is possible to change, without problems.
Typically in a larger turbo scenario we recommend a stage 2 flash which will increase duty cycle on the injectors and we only use the JB4 to get the correct boost curve if fueling allows.
