(#1126)
Onelowvdub Onelowvdub is offline
Car: Mk7.5 golf GTI dsg dq381
Default 04-24-2022, 10:57 AM
Ok sounds good I didn't know there was another way to change it .out of the box was 60 and I still couldn't get it to lean out .thanks again
Gti3 Gti3 is offline
Car: 2020 Mk7 Gti DSG
Default 04-25-2022, 05:28 AM
Hi George
I purchased a used JB4 which was being used on a Mk7 Clubsport.
My car is a 2020 7.5 Gti DSG - 169kw. I am located in South Africa (Durban).
The JB4 firmware version is 60/88//5. I am currently running the car on map 1 with no hardware mods. Am I all good here? or is there a setting where I need to change the car from Clubsport to regular Gti ?
Also - I intend on fitting a ******* ********. Can i run map 2 or 3 with just this ******* ********, or do I need an intake as well ?
Regards.
Moderator
Default 04-26-2022, 08:03 AM
Originally Posted by Gti3
Hi George
Regards.
Due to the 95ron available there map 1 is the recommended map. The maps are more based on octane than hardware mods.
2021 VW Golf 8 R
Default 04-26-2022, 12:49 PM
Thanks George. I take it that I don't need to change any settings even though the JB4 came off a clubsport? Assuming map 1 is the same for both cars?
Moderator
Default 04-26-2022, 01:00 PM
If the unit has shipped settings no changes needed.
2021 VW Golf 8 R
Default 04-27-2022, 11:07 PM
Perfect, thank you.
Hally83 Hally83 is offline
Car: 2021 Mk4 Skoda Octavia RS 245HP
Default 05-07-2022, 07:45 AM
Hi George. Do you have an update on the firmware for the Australian/South African MK8 GTI / Skoda Octavia VRS MK4 with IS20? Is it ready yet?
Moderator
Default 05-07-2022, 08:30 AM
I dont. I am battling to get a car for testing. On 500 odd cars where delivered in South Africa so they are hard to come by. Tuning wise nothing will change we will just add the ability to use boost per gear and timing corrections reading for guys that want to do custom maps.
2021 VW Golf 8 R
eeth1963 eeth1963 is offline
Anselm
Car: 2014 MK6 Jetta
Default TCS Control Possible? - 05-23-2022, 09:42 AM
Hey guys!
I just got my JB4 installed for my mk6 a couple days ago and it's such a huge difference! I was curious. Would it be possible for a future update to have the ability to turn off/on TCS? My SE doesn't come preinstalled with a TCS button, so I would have to wire and code one myself. I was wondering if this has the the possibility to be a feature with the JB4? Or should I just go ahead and grab a kit to install a button?
Preciate it.
Moderator
Default 05-23-2022, 09:48 AM
Originally Posted by eeth1963
Hey guys!
Preciate it.
Unfortunately this cannot be done with the JB4.
2021 VW Golf 8 R
AlltrackAttack AlltrackAttack is offline
Car: VW Alltrack
Default 07-26-2022, 02:55 AM
Hey guys!
Preciate it.
For something like that you'll need VCDS or OBDeleven. The JB4 is amazing and have a blast with it! For option changes OBDeleven will be you're best bet.
mike82smile's Avatar
mike82smile mike82smile is offline
Car: Ferrari
Default Today, 06:34 AM
Cool!
