(#1376)
infliktyd135i's Avatar
infliktyd135i infliktyd135i is offline
Car: 09 135i
Default 08-16-2021, 11:42 AM
Hey guys, I'm looking into getting a rs3 but don't know much about Audi. Which Audi forum is the "best" for reading up on rs3 modding and tuning besides this one? Thanks
Bullitt1841's Avatar
Default 08-16-2021, 11:47 AM
If you're in the US, I've found this one to be the best: RS 3 Specific
Just like bimmerpost, sometimes people can be a little arrogant. But at least most people actually wrench on their cars on audizine.
Car: 09 135i
Default 08-16-2021, 03:46 PM
Cool, checking it out. I see that you have some APR parts. 034 motorsports is a bit more local to me, do you know if they are still a reputable company in the Audi scene?
Default 08-16-2021, 03:57 PM
Yes, I run 034 dogbone inserts and rear subframe bushing inserts. They are very reputable in RS3 scene. The only reason I have the APR ECU flash is because they were the only tuning company that supported 100% E85 without any hardware changes. I think 034 requires bigger port injectors, still, but that could have changed.
Car: 09 135i
Default 08-16-2021, 05:00 PM
100% e85 does sound nice on oem hardware. Looks like a fun platform for fbo+ DD
tegxsi tegxsi is offline
Car: RS3
Default 08-16-2021, 08:54 PM
None of the stage1 E85 flashes require larger injectors.
APR does not require larger injectors for their stage 2 E85 but this does not exist anymore since they dropped all stage 2 tunes and related hardware.
Most other stage2 E85 tunes do require upgraded injectors.
Upgraded injectors are recommended on stage 2 E85 because the stock port and DI injectors are at the limit.
I have DS1 tune and I've calculated the stock port injectors to be about 160-170cc. Really small...
2018 Audi RS3
2013 Mazdaspeed3
2007 Acura TSX
weebles weebles is offline
Default 08-25-2021, 07:37 PM
Originally Posted by kornsined
Right now in Edmonton with Petro 94, I can't run higher then map2. Hopefully you have better luck.
Run Husky 94, it's by the far the best gas in Alberta. Mix in some ethanol and you're stylin'
kornsined kornsined is offline
Car: 19 RS3
Default 08-25-2021, 08:02 PM
Let me know where you can find it in Alberta. They've stopped making it this year. I agree it WAS the best gas available.
julian2292 julian2292 is offline
Car: bmw 1m
Default 09-07-2021, 08:00 PM
Hi, there are new news of the jb4 + tune stack?
I read about your audi ttrs Apr + jb4 testing.
did you get better drag times ??
2Y2Y's Avatar
2Y2Y 2Y2Y is offline
Car: TTRS 8S
Default 02-12-2022, 02:44 AM
Hello PeepsÖ
TTRS 2022, anyone know what these codes are ? Itís off the Jb4 Bluetooth scan
P42F9
P42F2
Moderator
Default 02-12-2022, 04:13 AM
Originally Posted by 2Y2Y
Hello PeepsÖ
P42F9
P42F2
Here is a list of code translations: https://docs.google.com/spreadsheets...f=true&sd=true
2021 VW Golf 8 R
2Y2Y's Avatar
Car: TTRS 8S
Default 02-13-2022, 10:33 AM
Thanks !
2Y2Y's Avatar
Car: TTRS 8S
Default TTRS 8S 2022 - DP + MidPipe - 02-13-2022, 11:16 PM
Here is a snap shot of my logs
2Y2Y's Avatar
Car: TTRS 8S
Default 03-14-2022, 06:01 AM
Does anyone know how to activate antilag on the jb4 ?
Moderator
Default 03-14-2022, 08:31 AM
The JB4 for this model does not support Anti Lag.
2021 VW Golf 8 R
2Y2Y's Avatar
Car: TTRS 8S
Default 03-15-2022, 01:30 AM
snap, for some reason I thought it did. My bad
MAP2 all day everyday -- loving it !
bmw loe's Avatar
bmw loe bmw loe is offline
Car: e92 N54 335i
Default 04-04-2022, 12:44 PM
Hey all, did the no boost issue get resolved?
BMW M4cs
TT-RS
Moderator
Default 04-04-2022, 12:53 PM
Yes, we havent had a report for a while now since the fix.
2021 VW Golf 8 R
leadfoot leadfoot is offline
Car: 335d
Default 04-04-2022, 02:56 PM
Yup.. resolved a while ago and works great. 👍
bmw loe's Avatar
Car: e92 N54 335i
Default 04-05-2022, 04:10 AM
Are these similar units to the group 7 on the 3.0t?
BMW M4cs
TT-RS
Moderator
Default 04-15-2022, 05:40 AM
Sorry missed this. Yes, similar to Group 7 but with different firmware.
The Group 7 do not have the chip set that solved the no boost issues for the RS3 though.
2021 VW Golf 8 R
RSthree RSthree is offline
Car: Audi RS3
Default Some guages stopped working on app - 04-24-2022, 06:04 AM
I have the jb4 with Bluetooth and an odd problem. Half the guages on the phone display stopped working. Eg, the revs don't register.
Is there a way to do a reset or should I delete and re add each of the guages that are not registering.
Moderator
Default 04-24-2022, 10:24 AM
This is typically a issue with the OBD cable. Double check both ends are connected.
2021 VW Golf 8 R
Car: Audi RS3
Default 04-25-2022, 01:11 AM
Thanks you were spot on. Had the car serviced and they pulled the obd plug and left it disconnected.
bmw loe's Avatar
Car: e92 N54 335i
Default 04-26-2022, 10:04 AM
Hey all, how do I know if I have Rev2? I see the JB4 I just received has a ground wire sticking out of the unit, not sure if that was for the BCM install piece? I didn't order a BCM module with the unit so wasn't sure if I needed to follow the BCM module because otherwise I would have 2 un-used sets of plugs vs just 1 set.
BMW M4cs
TT-RS
