8speednate 8speednate is offline
Car: Veloster N DCT
Default Meth Tunability with the Veloster N - 06-11-2021, 10:13 PM
Whats parameters have you guys changed to find they worked best on your veloster.
Car: 2020 Kia Forte GT
Default 06-11-2021, 11:22 PM
Start at 20-30 Boost Additive. What I've found that if you dramatically increase fuel quality the stock PCM is slow to adjust. By demanding less boost you can bring in the boost gradually.
The base settings in the directions are fine.
Watch your ignition advance you should be above 10 degrees advance during your log runs.
What is your current mixture?
2020 Kia Forte GT
6 Speed Manual
JB4+Bluetooth Connect
Rev9 Coilovers Corner Balanced & Aligned
13.75@102 Map 3
13.77@103
Map 7, E30+WMI, Hoosier Drag Radials
E85 Station Locator (US Only)
Car: Veloster N DCT
Default 06-12-2021, 09:19 AM
Right now I'm running boost juice but I would like to get m1.
Default 06-12-2021, 10:59 AM
You should be good to go.
With the 1.6L engine I've found Boost Additive 50-60 works best.
2020 Kia Forte GT
6 Speed Manual
13.75@102 Map 3
13.77@103
Car: Veloster N DCT
Default 06-12-2021, 03:13 PM
Hmm... I wonder what I should do for the 2.0T motor. I haven't had luck with temps dropping yet.
Default 06-12-2021, 03:22 PM
Are you sure there is flow?
You should be 10-15 degrees below what you are normally with it off.
Last time out 89-90 degrees ambient, 78 degrees at the end of a 1/4 mile pass.
The longer its on the more the temperature drops. Did you do a purge of the system after installation?
2020 Kia Forte GT
6 Speed Manual
13.75@102 Map 3
13.77@103
Lil Ripper's Avatar
Car: 2019 Veloster turbo
Default 06-12-2021, 05:06 PM
Has the( meth trigger mode) been selected in the (user adjustments)
Car: Veloster N DCT
Default 06-12-2021, 09:10 PM
Meth trigger mode for my map 6 is 0 same as the meth saftey.
I do get wmi flow on logs and gauges buy temps are ok on a 3rd gear pull 2500-redline ambient is like 78-85 I'll get a 93 lowest iat then it starts increasing after that halfway through the pull.
Car: Veloster N DCT
Default 06-12-2021, 09:11 PM
I most definitely purged. I'm not sure but I'm not getting anywhere below ambient. That's why I'm trying to see what parameters I can change.
Lil Ripper's Avatar
Default 06-13-2021, 03:36 AM
What is the minimum flow boost setting at?
Is your inline filter on the solenoid installed with the proper flow direction?
Is the filter dirty?
Is the nozzle dirty ?
Did you pull the nozzle from the charge pipe to see how it was spraying?
You can only set when the pump comes on and your boost Additive... Neither of these change the rate of flow from the pump.
I would just check your install and go over it and look for anything that may impede flow from the tank to the pump to the solenoid and nozzle.
Car: Veloster N DCT
Default 06-13-2021, 02:51 PM
I've checked many times and no issues.
Lil Ripper's Avatar
Default 06-13-2021, 09:03 PM
What nozzle Are you using?
Lil Ripper's Avatar
Default 06-13-2021, 09:08 PM
My meth trigger mode is set to (1) in the user adjustments.... Sprays on all maps
Car: Veloster N DCT
Default 06-14-2021, 12:11 AM
Bms recommend nozzle
Car: Veloster N DCT
I am currently testing in map7
Default 06-14-2021, 12:21 AM
I am going to assume a BM7?
During the day you should be able to go well below ambient temperature.
It's harder at night since the air is cool already. As I said WMI really shines when it's hot.
Also if you are using the BMS nozzle adapter, that temperature is being taken right at the sensor location. That is a good idea but not what it is by the time it hits the throttle blade.
With 50/50 ish I gained 14-16 whp over pump gas. About the same gain with E30 blend in the fuel tank, in other words I make 250+ hp Map3/Boost Additive 50-60.
That should result in 1.5-2 mph increase in trap speed (1/4 mile)
2020 Kia Forte GT
6 Speed Manual
13.75@102 Map 3
13.77@103
Default 06-14-2021, 08:52 AM
If you're gauging WMI performance off IAT drops you're doing it wrong.
Gauge WMI performance off fuel trims and timing corrections.
Car: Veloster N DCT
Default 06-14-2021, 11:06 AM
Gotcha. Becuase the iat are doing OK. I will look further into it.
Car: Veloster N DCT
Default 06-14-2021, 11:08 AM
What does "min advance" do in wmi settings. Becuase when I set it to 0 while on map7 it reverts to map0.
