brooks1005 brooks1005 is offline
Car: 2013 BMW 335i
Default Fault code with BEF/JB4 - 11-07-2020, 11:01 PM
I reinstalled everything as usual and then used MHD to add the BEF. I drove around town and then took a trip to a friends house an 1.5 hours away. The car ran like a beast. Parked the car for a few hours and when it was time to leave the car would start, sputter and then die. I was able to get it in the driveway at the friends house. Something told me the JB4 was the culprit. I took out the JB4 and the car started like nothing happened. I did get codes 2c58, 2c6f and 2c70.
2013 BMW 335i Coupe M-Sport, BMS Intake,FTP charge pipe, JB4 Stg 2 w/BEF, Active Autowerke D**npipe, Rev9, XHP stg 3
Default 11-08-2020, 09:05 AM
Something with the TMAP connection/boost sensor. Perhaps a loose OBDII connection?
Car: 2013 BMW 335i
Default 11-08-2020, 05:10 PM
I assume after removing the JB4 the BEF is still present? If it is, do I need to flash my MHD stage 2+ bin from before until I have more time to work through my issue?
Default 11-08-2020, 09:46 PM
You can run on the BEF only while sorting out whatever your problem is, or flash to Stage0 stock tuning if that's easier. I wouldn't waste money on another flash map.
Car: 2013 BMW 335i
Default 11-10-2020, 02:28 PM
How does your BEF compare to the MHD stage 2+ that I purchased months back?
