Banned
Car: 2009 Bmw 335i
01-12-2017, 11:35 AM
Originally Posted by Marcos_Nunes
Do i Have to uninstall MHD to do the flash?
no you dont
Car: 335i E92 2009
01-12-2017, 11:50 AM
No, have nothing to do with MHD , TCU flash totally different than ECU
Car: E92 335i
01-12-2017, 11:56 AM
My car is on the limit off the month that is possible to flash the Alpina software.
Can i do it and get it back to stock if it goes bad?
Banned
Car: 2009 Bmw 335i
01-12-2017, 12:04 PM
yes
Car: 2008 135i M Sport
Winkfp guru required -
01-15-2017, 08:19 PM
Hello. I live in Australia and have followed this post in to flash to Alpina 7615835. I have since tried another flash (7615835) and was flashing to 7603537 when I had a fail at 1%.
I have been reading everything on the Internet and changing settings etc with no luck. Trebila mentioned to try the virtual box image for programming and still coming up with the same error.
I was wondering if someone could help me with this, I have been at it for 4 days now and just want to drive my car! Any help would be greatly appreciated. I can't do remote access right now as my home Internet is not working. Having said that I could tether off my phone! I really am desperate for a fix here.
I hope someone can help. Pic of the error window attached.
2008 135I M-SPORT. AT. ST GTX3076R. JB4/TREBILA BEF. XHP STAGE 3. PUMP98 & 70/30 METH DPI. FOCAL IFBMW-C +IFBMW-S.
Car: 07 e90 335i n54
01-17-2017, 12:54 AM
01-17-2017, 09:14 PM
I followed part 1 and part 2 of tose videos the first time I flashed. I have flashed again after that and failed this time. My egs is stuck in programming mode 12. I can't seem to access it with anything because it can't read the ecu identifier to make sure of a match.
Banned
Car: 2009 Bmw 335i
01-21-2017, 02:01 AM
Originally Posted by *****1967
Call me 503 679 3538
we tried flashing different methods... winkfp/nfs/istap/ etc with his k+d can cable all the software keeps failing... we tried disconecting the batt overnight,we hooked up a batt charger etc. nothing worked.. im thuking his k+d can cable might be defective.
Car: BMW e92
05-13-2017, 02:12 AM
hello guys, i have following errors while loading the flash. it sounds like WinKFP couldnt see TCU, any ideas?
Car: BMW e92
05-15-2017, 06:58 AM
no answer at all ?
Banned
Car: ST 335 N54
05-15-2017, 07:24 AM
i can help you get it back to normal. pm me
Banned
Car: ST 335 N54
05-15-2017, 07:25 AM
i can help you pm me
Car: BMW e92
05-15-2017, 01:02 PM
Mail sent
Car: 98 Vette 734 whp, 08 335i e90 n54
09-11-2017, 08:31 PM
Subscribed -
Thanks,Matt
Car: 2008 335i White on Lemon Dakota and Black
02-09-2018, 12:18 PM
This is probably a stupid question, but I just want to be sure. Does the Spdaten file need to simply be newer than 49.3 or does it need to be a specific Spdaten to work?
I believe I am already updated to 60.1 and just want to make sure it will work ok.
Thank you,
Kaz
Car: 2008 BMW 335i E93 N54
02-25-2018, 04:44 PM
I recently purchased a bimmergeeks cable and installed third version of 5.0.6 how can I tell if I have the correct sp Daten files a and as precious poster asked does it matter if I have a newer version
03-09-2018, 01:39 PM
I cant fine the pdf file to import the 53 SPDaten files? Trying to figure out how to update my winkfp app.
03-12-2018, 03:22 PM
Finally figured it all out. Was a bit of a PITA but wow was it worth the effort. I'm really liking it. Thanks to all that contributed to this great mod.
03-12-2018, 04:57 PM
Updating the daten files shouldn't be a PITA at all. Just open "BMW coding tool", select "Update SP-daten", select the daten folder to update to and it does it all for you. That's the best way to do it, super easy.
03-13-2018, 10:08 AM
In the coding tool there is also an option to update Winfpk should I have updated that as well?
03-14-2018, 12:05 AM
I believe so. Atleast I always update WinKFP, but it would be good to know for sure if anyone else knows the answer to this.
03-14-2018, 05:13 AM
I had to do more than just update the date files. I also had to copy three separate folders as well. I saw it on some YouTube video.. I was getting error 211 I believe something about security. But in the end I got it to flash. And it's the best bang for buck mod I've done so far.
03-14-2018, 03:27 PM
Supposedly xHP is significantly better than Alpina. It makes me curious, but I wonder how much of that is marketing hype.
Car: BMW E82 135is 2009
05-04-2018, 08:29 PM
I had this flash and it worked fine but every once in a while I would get half engine light and when I checked codes it would show EGS not coded. Should you do coding after the flash in NCS expert or does WINKFP do that for you? I have since flashed back to stock.
08-04-2018, 08:19 PM
No I programmed it back to oem with oem Bmw software and it’s been fine since. So your telling me program Alpina then code it to oem coding?
