mpmotorwerks mpmotorwerks is offline
Default Log review - 05-20-2019, 01:52 PM
n54 turbo hybrid full bolt on log review
Default 05-21-2019, 03:47 AM
Quite a few timing corrections- what fuel?
Your LPFP is pretty maxed out- you hit the 40s toward the top of the pull, id reduce boost a bit up top to rectify that.
A bit more detail would help- fuel, turbos, fuel mods etc
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-21-2019, 04:20 AM
Just installed the pure turbos. Full Bolton w meth. Running premium gas. Nothing has done with fueling system
Default 05-23-2019, 12:22 AM
LPFP looks maxed- need to upgrade that ASAP- I’d lower boost or run a much less aggressive map 6 settings up top until you can address that
Getting multiple timing corrections as well.
Did you setup that map 6?
Default 05-23-2019, 04:41 AM
I did the backend flash race map. Running on default map 6.
Default 05-23-2019, 11:07 PM
Run a much less aggressive map until you can address the LPFP
Letís see a log of map 1 or 2
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-24-2019, 05:15 AM
Here is the log review on map 2
Default 05-24-2019, 06:55 AM
Overboosting a bit, but at least your LPFP is in the 60s & not tanking.
Lower your DB setting by 10 from 3k to redline.
e92 AT 335xi 2.0
Doc Race Kit 6062
Default 05-24-2019, 07:15 AM
Ok thank you. Decided to address the LPFP
Default 05-24-2019, 12:38 PM
Install & we can turn back up a bit
Play it safe until then
e92 AT 335xi 2.0
Doc Race Kit 6062
