madking187 madking187 is offline
Car: BMW 340i 2017
Icon1 JB4 as WMI controller? - 01-25-2019, 12:56 AM
Hello team,
Is it possible to use JB4 as WMI controller?
As example if I flash my car but I don’t want JB4 to interfere the timing table, boost ,,etc
It will be great if we can use it like a standard alone controller.
“Good even for selling advantage ”
Maybe in map6 with zero add boost?
Or you can configure map8?
Looking for your kind reply
2017 340i M bodykit
mods:
Sport Springs
K&N drop-in filter
VRSF D0wnP!pe
JB4
Default 01-25-2019, 01:59 PM
Yes, we have maps setup for just that purpose. Flash away, post a log on map0 here, and we'll help you dial it in.
grasso91 grasso91 is offline
Car: 2018 340i
Default 01-26-2019, 07:24 PM
Hey Terry which map can I use to control meth without the JB4 interfering with my flash tune?
Stani Stani is offline
Car: BMW m140i
Default 02-22-2019, 04:41 AM
Hello ,
map7
Booster aditive 0
Signal scaling 60
Min flow booster 10psi
Stan��
Brett530 Brett530 is offline
Car: 340i
Default 02-27-2019, 12:04 PM
Terry,
I flashed to a Stage 1 tune (16PSI) about a week ago and have JB4 on map0. I'd like to re-enable my WMI but I'm unclear if I need to use Map 7 with certain settings, or if I need to get custom firmware that will not affect any of the settings controlled by the flash tune. If it is just Map 7, what settings do I use?
dRDiesel's Avatar
dRDiesel dRDiesel is offline
Car: BMW
Default 02-27-2019, 12:14 PM
Originally Posted by Brett530
Terry,
Terry said post a log with your stage 1 flash and JB4 set on map 0 and they will help you dial it in. Logs need to be looked at so they can help you set the starting meth injection and everything else that needs to be dialed in.
