madspeed madspeed is offline
Car: Audi S3
Default Datalog missing info - 09-19-2018, 05:26 PM
Hey guys, I have a recently installed JB4. I connect my android phone via otg cable and can connect without problem. Ap confirms map2. When I view gauges the only one that works is boost. I tried a datalog and only boost pressure was recorded. Is there a setting or something that I have missed??
Default 09-20-2018, 11:59 AM
You need to check to see if the OBD cable is installed correctly. Check the small end that connects to the JB4 and you will notice it has some small angles on the plug, match male to female sides and evaluate if you getting the data through.
Car: Audi S3
Default 09-20-2018, 12:35 PM
I sent a message to the JB4 connect email address as i believe something else is faulty. Tried connecting again and getting this message
Car: Audi S3
Default 09-20-2018, 12:45 PM
Went out and disconnected the JB4 to OBD port cable. Reconnected and was able to get signal again. Looks like we're good for now. Time to go get some logs!
Default 09-20-2018, 01:45 PM
Happy its sorted.
