(#3676)
Creative911 Creative911 is offline
Car: F10 535i M Package
Default 05-31-2019, 03:29 PM
It's fine here, add a JB4 log though for any tuning advice!
Here is the log from a pull I just did, only change is that I added E85 (30%).
Default 06-12-2019, 10:40 PM
Any help on this is greatly appreciated
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 06-13-2019, 04:41 AM
Post the actual log not a image of the graph.
'14 435I RWD MHD "Twisted Custom Tune" ° BigBoost Stage 3 Turbo ° PR Coils ° XHP Trans Tune ° GFB DV+ ° VRSF Race Cooler ° VRSF CP ° BMS Intake ° Borla ATAK Exhaust ° Custom Down-pipe ° stage 3 LPFP ° BMP4 EKP ° M Performance LSD ° Phoenix Racing PI Intake Manifold ° AIC2-P controller ° e85 ° 3.5 TMAP ° NGK 5992 Plugs "0.020"
135idct 135idct is offline
Default 06-26-2019, 07:04 PM
try this one
VTR VTR is offline
Car: bmw e82
Default 07-04-2019, 11:35 AM
What is the latest version of Firmware?
Could someone tell me where to download it?
Thank you!
Default 07-04-2019, 11:37 AM
Depends on the model car! EWG or PWG. Sig says you have E chassis?? This is F chassis.
5soko's Avatar
5soko 5soko is offline
Vintage
Car: F10 N55 PWG
Default 07-04-2019, 06:22 PM
Loading up the latest PWG firmware.. How has it been working for everyone?
Im assuming the default N55 settings and the duty bias values are for PWG aswell?
2014 F10 535i N55 PWG
e46m3to335i's Avatar
Car: 2015 F22 M235i
Default 07-09-2019, 02:24 PM
Is it possible to monitor Meth flow and Ethanol content at the same time on the App? I'm guessing not since both require pin 16 for signal. Just trying to confirm
Default 07-09-2019, 05:05 PM
Yes, it is. There are alternative E85 inputs. For EWG systems we have a V2 board now that has an extra analog input on the DB9 for low fuel pressure or E85 for cars equipped with WMI (that already uses the 2 extra DB25 connections)
Car: 2015 F22 M235i
Default 07-09-2019, 05:33 PM
Thanks for the reply Terry,
Do you have a link for the V2 EWG board? I can't find it on the BMS website. Just to confirm, in order to monitor ethanol content and WMI, the V2 board is required?
Ultra_435xi Ultra_435xi is offline
Car: F32 435i xdrive
Default 07-14-2019, 04:50 AM
What is the latest firmware for Ewg ? Ewg 17 t2 or ewg 16 test5 ? Im a little bit confused.
Greetings from Germany
435i xdrive
Car: 2015 F22 M235i
Default 07-15-2019, 09:21 AM
rusty13 rusty13 is offline
Car: BMW M135i
Default 07-15-2019, 01:12 PM
What’s the firmware change log for EWG 17 t2?
JLBimmer's Avatar
JLBimmer JLBimmer is offline
Car: 2016 435ix GC
Default 07-15-2019, 01:50 PM
Hey Terry is there a way to fix the Fault code that comes with the EWG harness? I am getting them randomly. I have been practicing the ACC on before Start trick but still is comes up from several times a week at start
JL Bimmer
2016 435ix Gran Coupe
HRP Cold Air Intake, Charge Pipe, Turbo Up Pipe, Turbo Intake Pipe, BMS Intercooler, Axle Back Exhaust, JB4
H&R Springs, Sways, Strut Tower bar, 19"x10 Rotiforms, Too much carbon goodness
Lipper Lipper is offline
Car: 2015 M235i 6MT
Default EWG 17 t2 - 07-15-2019, 08:27 PM
Are there release notes for the new version? I'm running EWG 15 and wondering if it's worth the upgrade.
Thanks - Ken
Endeav Endeav is offline
Car: BMW M2
Default 07-16-2019, 07:42 AM
Thanks - Ken
Also interested in the release notes!
Thanks BMS for all these updates!
'17 BMW M2 - [DCT/N55] - PureTurbos Stage 2 Turbo - JB4 + MHD BEF - Fuel-It Methanol PI
tauzins tauzins is offline
Car: 2014 335i m-sport
Default 07-16-2019, 01:05 PM
Agreed, i didnt even know there was a new version because i always looked at the notes to see if a new ver. came out.
sdhasher21 sdhasher21 is offline
Car: 2016 M235i
Default 07-19-2019, 05:05 PM
Likewise. Would love to update this weekend, depending on what the changes are.
nobu5552 nobu5552 is offline
Car: F10 535i
Default 07-22-2019, 08:04 AM
I tried using 17 firmware. However, the boost was 27 PSI with the 7th to 8th speed half accelerator in high gear. I thought that the engine would break. DME error code 101f02 was also issued. I think it is better not to use it because it is dangerous.
2014 535i / ZF 8 / M-Sport / MHD Back-end Flash / XHP Stage 3 / AT / ** / Valve Straight Muffler / FTP Boost Turbo Pipe / Wagner Intercooler /
BMS intake / forge valve
Car: 2015 F22 M235i
Default 07-22-2019, 08:21 AM
Yikes!!
smahel smahel is offline
Car: 335Ci
Default 07-23-2019, 03:01 AM
I tried the EWG 17 T2 too, the map 6 that I use, seems to me much less consistent, the boost was like usually, no codes. After turning off the car, the firmware forgets some in dash settings. So I'm back on the EWG 16 T5. Here is everything O.K.
5soko's Avatar
Vintage
Car: F10 N55 PWG
Default 07-23-2019, 01:23 PM
Isnt all 2014 535i's PWG?
Car: F10 535i
Default 07-24-2019, 06:28 AM
My car is an EWG vehicle. The use of the 17EWG firmware was really scary.:eek:
mversi mversi is offline
Car: 2017 BMW M2 LCI DCT
Default 07-25-2019, 05:02 PM
Anyone running firmware 17_T2 on a N55 M2? I have a Wagner ** & IC and BMS intake and the car only seems to be hitting 14PSI on Map2, same as it's getting on Map0 !
tpayne1305@gmail.com tpayne1305@gmail.com is offline
Car: 2014 F10
Smile User Adjustment N55 Default Settings - 07-31-2019, 03:12 PM
Do I input the N55 Default Settings parameters that are attached to the F Chassis N55 JB4 page into the User Adjustment tab via the iPhone? New to this so I just want to make sure all is set up right...I uploaded the new version of Firmware and selected Map 5 to run. Please assist with the above question, thanks!
