(#151)
YoungMulla's Avatar
YoungMulla YoungMulla is offline
Car: 2012 BMW 135i 6mt
Default 08-28-2018, 03:42 PM
Hey guys, I had a quick question. I have a 2016 M550i f10 with the newer n63tu2 motor. Do I still purchase the regular n63tu beta jb4? Is going the extra mile and getting the bcm right off the bat worth it? or should I enjoy the jb4 a little and then add the bcm later on. And also any updates on the intake?
Default 08-28-2018, 03:45 PM
Are you G chassis or F chassis?
PS. I'm giving you N63/N63TU guys your own forum!
YoungMulla's Avatar
Default 08-28-2018, 03:53 PM
F chassis. I was reading somewhere that the MAF plugs are different in the tu2 and don't need to be unplugged after installing a jb4. How true is this?
2016 M550i
2014 M640i GC
2013 M750i
2011 M135i 6-speed (WIP)
2010 M135i 6-speed, D*, CP, IC, Intake, Tune, BOV, Exhaust
Default 08-28-2018, 03:58 PM
I'd skip the BCM to start and just run the basic JB4. Later if you get bored, then add in the BCM. The BCM for those is great but it's like 75% of the install effort compared to just the JB4.
YoungMulla's Avatar
Default 08-28-2018, 04:00 PM
I don't mind installing the bcm. I have my own shop with lifts and everything so shouldn't be too hard.
2016 M550i
2014 M640i GC
2013 M750i
YoungMulla's Avatar
Default 08-28-2018, 04:13 PM
Will i need a down pipe and/or charge pipe or any other to run a bcm all out with e30? or is stock just fine. I know in the n54/55 you need to change out the charge pipe and down pipe to run e30
2016 M550i
2014 M640i GC
2013 M750i
Default 08-28-2018, 04:21 PM
Not needed to be honest, but it could probably help. d0wnpipe is illegal though and should be for off-road use only.
YoungMulla's Avatar
Default 08-28-2018, 04:25 PM
oh yea of course! This is strictly ONLY a track car
I just love the sounds these motors make with an exhaust
2016 M550i
2014 M640i GC
2013 M750i
Car: 2010 535
Default 02-06-2019, 01:27 AM
Terry, Are you still selling the N63 JB Stage 1 to JB4 Beta upgrade kit?
M335's Avatar
M335 M335 is offline
Car: 2011 E90 335i
Default 03-04-2019, 11:37 AM
Can we get a V2 board/firmware for the N63tu platform for guys with PS2 or even bigger custom turbos?
F10 N63tu @FrozenF10 Grey with full OEM M5 conversion Beta JB4/BCM, GTX3076r | F10 stealth progressive meth| Custom inlets with CAI | Eibach springs| custom exh**st with 😼less dwnps |
E90 N55 VS2 DBB with custom inlet-short air intake | BMS JB4/MHD bef/ISO+FF wires E50 corn | 100% Meth-Injection | BMS-occ,cf,ocv, | Big Tom FMIC | Fuel-it S2 LPFP | 5" CP-E ** | BMW-pe |
Default 03-04-2019, 04:56 PM
Our current N63TU systems systems use the V2 board and integrated PWG connections for the harness.
M335's Avatar
Car: 2011 E90 335i
Default 03-04-2019, 08:57 PM
Is thatís mean we can control the wastegate in each side of the engine independently with V2 board for n63tu and upgrade old jb4 to V2 board for $200 +shipping?
Default 03-05-2019, 12:06 PM
Yes the same upgrade kit we offer for the S63TU should work, you'd have to update the firmware to N63TU V2 firmware.
Drottam Drottam is offline
Car: F10 550i N63tu xdrive
Default 03-05-2019, 07:09 PM
Thatís great news! Is there an exchange program? If so what all do we need to send back? Does V2 require a new harness too?
Thanks in advance.
F10 N63tu 550i Xdrive Msport, Imperial Blue Metallic, Beta JB4 w/BCM, Frequency intelligence catback, 20" Matte Bronze Ferrada F-8 wheels, H&R springs - WR 11.057@123.19 quarter mile
bryanZ bryanZ is offline
Car: 2015 650i vert
Default 03-06-2019, 01:35 PM
do you still have to hook up fuel wires with the v2?
Default 03-06-2019, 03:40 PM
We no longer offer fuel pressure connections for it.
Default 03-07-2019, 09:00 AM
Does that mean V2 will not support fuel connections Iím using with V1? If there are no fuel connections is the dme still able to keep afr in the correct range?
ceboo ceboo is offline
Car: F30 335xi
Default 02-05-2020, 02:21 PM
Hi iím looking to get the jb4 for my 550i f10 16 N63tu
Iím wondering about the installation;
for the n63tu apparently we have to unplugged the MAF sensor and its provide
a check engine?? What thats meant? You always get the check engine on with the jb4 installed?
This issue is still on for the recent version?
Thanks for any help
Splittlive Splittlive is offline
Car: BMW 550i F10
Default 02-05-2020, 04:50 PM
Thanks for any help
No, the newest version clears the code upon starting the car.
Car: F30 335xi
Default 02-05-2020, 04:57 PM
Hi
Thanks for your help.
Its a good news, but can you clarify the code is erased or reset upon starting the car? Nothing to do or you always have to go thru the phone app to delete the code?
Car: BMW 550i F10
Default 02-05-2020, 06:26 PM
It clears the code each time the car is started automatically. My experience is I do not have to launch the app for the code the be cleared. When I start the car no CEL comes on.
Car: F30 335xi
Default 02-29-2020, 03:54 PM
is that me or thereís relatively no reviews on the newest version with bcm integrated..?
Have a 16 550i and iím impress by the numbers advertised!
But what about reliability of this compare with the one for the N55/N54 with lot more tester on the market?
Repo335i Repo335i is offline
Default N63 tu - 05-18-2020, 10:41 AM
do I have to connect the bcm? and which maps can I drive without Bcm and without hardware changes? can I drive map 2 and if so, how much power does map 2 bring?
Car: F30 335xi
Wink New oem bosch plugs - 05-19-2020, 07:15 AM
Question is for Terry
I have a 16 550i f10 that i just changed the plugs
Oem Bosch
My question is , according to you
Could it be fine to add the jb4 only with Brand New OEM plugs
and no other mods...
Or you ABSoLuTELY recommends to switch with ngk to avoid misfire?
Car have 45k miles for info
New (oem) plugs have not even 500km....
Thanks appreciate your help!
