Spade's Avatar
Spade Spade is offline
Car: Jetta 1.8T/Cooper S
Default E85 Mix - 12-20-2018, 10:33 AM
I believe I asked several months ago on Vortex.
Anyone running a partial E85 tune? How rich can we get stock injectors to flow?
I know it's not as easy as a new Mini or BMW but can we run a solid 1/3 E85 and have tune adjusted for it as to not run lean?
I am currently running George's revised Map 6 created when my 1.8T Jetta was stock other than air filter. It now has lost the 2nd *** and has a straight resonator. Perhaps we can do a bit of revising although primary *** is still there.
I'm currently running a 88 (15% ethanol max) and E85 (minimum 51%) mix. 4.5 gal of E85 and 9 gal of E15. I've gotten EPC light but very rare. If using a higher minimum ethanol pump I'll dial back to mix to 4 gal.
Any input appreciated. I'm a cheap ass and plan to switch to Jetta from Mini (N14) for track days. So 2.5 hours at Sebring raceway is considerably cheaper when not running 93.
Spade's Avatar
Default 12-20-2018, 10:34 AM
I guess *** is kitten
Default 12-20-2018, 12:59 PM
Typically we don't suggest going higher than E35 but its also relevant to how aggressive the boost is set. At a certain point the trims will max and AFR will run lean so this needs to be evaluated with some logging.
Spade's Avatar
Default 12-20-2018, 02:00 PM
OK I'll probably do a log in Map 4 with that fuel mix.
2014 VW Jetta 1.8T 5MT
214WHP 237WTQ, Dynojet, JB4
2009 Mini Cooper S 6MT
287WHP 307WTQ, Dynojet, Manic
Default 12-20-2018, 02:02 PM
Map 4 will target stock AFR levels so I doubt you will see any change. Best to test with the tuned maps.
Spade's Avatar
Default 12-20-2018, 02:09 PM
OK I'll leave it on the 6 you made for me earlier.
