(#2651)
Bullitt1841's Avatar
Default 06-21-2016, 08:55 PM
@ MHD
Is it possible to only enable the burble when in Manual mode on an AT? I have noticed horrible MPG and overall bad drivability when coasting and cruising in Auto mode.
IanWRX IanWRX is offline
Car: 07 335i
Default 06-22-2016, 01:10 PM
My car burbled and popped all the time on its own and now it doesn't. Was it something changed in the tune that stopped it?
nika1993's Avatar
nika1993 nika1993 is offline
Car: bmw 535i
Default error 3 - 06-23-2016, 10:58 AM
Error 3. mhd not conected with car.
jtrejo jtrejo is offline
Car: 535 2008
Default 06-23-2016, 06:55 PM
i installed latest update and now i have the traction control light on, anyone have this issue?
2015 535 - JB4 - VRSF pipe- Burger Intake - Straight piped - MHD Backend Flash
chatz86's Avatar
chatz86 chatz86 is offline
Car: 08 E92 335i N54
Default 06-23-2016, 08:12 PM
Menu 6/Option 4
2008 e92 335i M-Sport|JB4 G5|MHD BMS BEF|BMS DCI|VRSF DP|Alpina 7603537|BMS OCC|RB PCV|Stage 2 LPFP|Fuel It! ES-1 fuel lines with Ethanol Sensor and JB4 analyser|MMP Silicone Inlets|4 Bar TMAP|VRSF 7" FMIC
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-24-2016, 01:15 AM
Originally Posted by pepper135i
I'm running the backend MHD not standalone
Burble flash option doesn't depend on the map you flash so csutom map, ots maps, backends maps, even stg0 map are compatible.
Originally Posted by Jeffman
Not exactly.
After the advanced options screen, but before flashing, I went to get the charger when told it would be a longish flash. I had not affirmatively started the flashing - at least I believed I hadn't started the flashing. Not sure what happened. I've been a Cobb user for four years and the UI is just a little bit more idiot proof IMHO. I'd like MHD app to also be a little more idiot proof. Just say'n!
I may add a confirmation for long flashes only. In your case that's pretty certain your started the flash.
Originally Posted by RSicks
I dunno then. I did a couple back road 0-100 runs then went through the same parking garage @4000 in Sport Mode and still nothing. Flap is active so that may be why.
Just weird that the flap is making it completely not noticeable at all at 3 sec / hard.
Well, good news we are working on flap control.
Martial, I figured it out. It was the app itself. I was going over every scenario I could on why my car was having the issues. It was not flashing through the app correctly. I deleted the app and reinstalled. On the newly installed MHD, I did another flash and it took. Now this does scare me a touch because now it works... Wth was being installed when I was flashing previously? Anyhow it works fine after reinstalling the app.
May want to suggest every once in a while after updates to start clean especially due to the sensitive nature of the app. Otherwise another kudos from me!
If you had the burble option before, the flash will produce the same output, deinstall or not since it doesn't depend on anything else.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-24-2016, 01:23 AM
Originally Posted by boostking510
Hello,
I had the BMS backend flash installed with the BT cable from someone on the forums. Can you give me instructions on how to UNINSTALL the BMS backend flash using MHD and tablet? Where do I go? What thing do I select to put it back to stock?
I am planning to flash a different card (335i). Currently I was using map 7, backend flash, and e70mix. Power was insane. Is there an MHD map that is like that, basically that lets you run and is tuned for high levels of ethanol?
Just overwrite. Don't do a ECU backup if you had a bimmerboost flash.
The equivalent of map 7 + e85 backend would be the e40 v5 map. There's little gain going over e40.
Originally Posted by Bullitt1841
@ MHD
I will think of this, it's possible but I don't want to add too many settings and confuse people.
Image is not there. Drop me a mail or use Facebook messages to get quick support.
qgshadow qgshadow is offline
Car: BMW E82 2008
Default 06-24-2016, 01:39 PM
Anyone know which cable works with the MHD App on a tablet apart from the 70US one?
Thanks.
SteveTate SteveTate is offline
Car: 335is
Default 06-24-2016, 02:17 PM
http://bimmersoftware.com/Cables
This one...
darkrom darkrom is offline
Car: 135i N54
Default 06-26-2016, 06:26 AM
Is it possible to have an in car toggle for the burble setting? It sounds absolutely amazing and I love it, but it would be 10x better if I could toggle back and forth. The highway crusability isn't great with 5 seconds of aggressive burbles, but it sounds so entertaining. I'd love to be able to choose if I'm out for a serious drive or a fun run. I don't think my boss appreciates it as much as I do
nika1993's Avatar
Car: bmw 535i
Default 06-26-2016, 09:18 AM
Why mhd flasher is not available for my country?
HairyWelshSteve HairyWelshSteve is offline
Car: '07 335i MSport Convertible
Default 06-26-2016, 11:00 AM
Your country being?
| U.K. 2007 E93 335i| JB4 G5 I8A0S Pump Flash| Scoops | BMS DCI | CKS Performance 3" *** | MMP Silicone Inlets | Active Autowerke 5" FMIC | CDV delete |Fob Roof Controls | JB4 Connect rev. 3|
nika1993's Avatar
Car: bmw 535i
Default 06-26-2016, 12:31 PM
Georgia Caucasus.
Default 06-26-2016, 12:58 PM
Georgia Caucasus.
There is no Google Play Store in Georgia as far as I can tell. Do Google Play services work though? If so, I'd have thought you could get the .apk from someone and then the licensing would work.
Jeffman's Avatar
Jeffman Jeffman is offline
Car: 335xi
Default 06-26-2016, 02:22 PM
Maybe some enterprising person could load up MHD and all the options you want on an inexpensive android device and ship it to you?
Car: 2010 135i
Default 06-26-2016, 03:24 PM
@MHD
I know the answer is posted somewhere, I didn't find it though.
I had flashed with my tablet. I now want to switch to my new phone.
How do I go about doing that? (the tablet will be sold and I will not have access to it)
2010 135i auto,
2020 mods: Speedtech S366, VTT DBBL, PR Coils, dual 450's, etc
Best stock turbo 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best stock turbo 1/4 mile: 11.480 @ 121.79 1.802 60'
Litebulb Litebulb is offline
Car: '09 SGM E88 135i
Default 06-26-2016, 06:10 PM
Just log into google play store with the same account you purchased MHD with and install it.
Originally Posted by iminhell1
@MHD
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
nika1993's Avatar
Car: bmw 535i
Default 06-27-2016, 06:49 AM
Someone send me an email apk file so that I could install mhd Flasher. gochaevich@gmail.com
Reiss91 Reiss91 is offline
Default 06-27-2016, 07:42 AM
Pleeeeeease add the option for manual mode only burble and no burble in drive. That would be awesome
Default 06-27-2016, 08:30 AM
I'd suggest you ask mhd.tuning@gmail.com to send you the apk
boost junkie boost junkie is offline
Car: bmw
Default 06-27-2016, 11:15 AM
Get it through google play store. If you just install the APK then it won't do you much good since the licenses required for the app to actually work have to be purchased through the store.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-27-2016, 04:00 PM
Any errors so far with the burble with catalytic ? A friend used the 3 seconds medium and he's getting 2C31 and 2C6B lambada probe in front and behind catalytic converter system check. Not sure if it's from burble
Default 06-27-2016, 04:08 PM
No issues on mine.
N54 | Build Thread
nika1993's Avatar
Car: bmw 535i
Default 06-28-2016, 09:50 AM
Why restrict my region? In my country, too, like n54 engine. Now, because of this limitation, I can not write the maps on your car
youraveragee90 youraveragee90 is offline
Car: 335xi
Default 06-28-2016, 09:52 AM
the noob back at it again just curious, if I run the 93 pump map on the mhd and I put in 100 octane will there be any drivability issues or will the car compensate for the higher octane?
asking this because once in a while when I go to my buddy's house in jersey on the way back to NY is the only 100 octane pump within the general area so its fun putting some of that good stuff in my car and I don't want to have to constantly keep switching to 98 octane because after its done I can only get 93 octane locally
thanks any info Is helpful!!
