(#10476)
Default 05-01-2016, 12:18 PM
Made a tweak in v32.4 to the 2STEP algorithm which I'm hoping will get it back to where it was previously. Those who are having issues load it up and test it out.
Kish2604's Avatar
Kish2604 Kish2604 is offline
Car: E92 335i
Default 05-01-2016, 02:25 PM
Terry... Small bug I found on 32.3 regarding the needle sweep on start up.. The speedo only sweeps just over half way through vs the Rev counter which goes the full sweep.
It's not life threatening so perhaps a look in the next version. I have not tried 32.4 yet
|RB old gen|Jb4 G5|3" DP's|ER Competition Cooler|ER Charge pipe|Tial BOV|CM Meth Kit|Dual nozzle setup|BMS cowl filters|AFE intakes+scoops|
|BMS low temp oil thermo|MHD flash + coding|HnR Springs|M3 Control arm kit + H&R + Koni|LED Angel eyes+plate lights
Default 05-01-2016, 04:58 PM
What dash type?
mike082802 mike082802 is offline
Car: vw passat
Default 05-01-2016, 06:40 PM
ever since 32.3 i haven't been able to get the warm up flash to work. i've been trying for a week. i have a 135.
nuttifriendivan nuttifriendivan is offline
Car: BMW 335i MT
Default 05-02-2016, 12:14 PM
Terry. I am givine the new ( 2 step) Revision a try to night! I will report with my findings.
2008 335i 6Spd Manual MMP Inlets- Clutch Delay Valve delete- BMS ********* - SLD- G5 Jb4/ USB. FMIC ******* DP's- M3 wheels- 2/step NLS- MHD custome e60 flash JB4 stacked - Walbro Inline Upgrade stage 1- 335is Clutch - DMFW - Pilot Super Sports -ECS tunning Chargepipe - w. Synapse BOV- Gutted 2ndary Cats - Throttle Body Port injection by Fuel -IT! Kidner grill,scoops.
Kish2604's Avatar
Car: E92 335i
Default 05-02-2016, 12:17 PM
What dash type?
E92 335i, euro spec... All settings correct...
Also the speedo doesn't exactly line up perfectly...
Default 05-02-2016, 12:53 PM
On the metric dash startup sweep a correction was made to v32.4 for it.
pukin_dog pukin_dog is offline
Car: BMW 335i
Default 05-02-2016, 05:35 PM
Originally Posted by wind
I updated steering wheel controls with last Terry's changes. If anyone would like to use it:
Full
https://drive.google.com/open?id=1Tp...zn6PZCffkMWBNo
Short
https://drive.google.com/open?id=1Cl...DDLjB_OP8d4tRM
Perfect! Thanks.
Car: BMW 335i MT
Default 05-02-2016, 10:27 PM
Terry i tried the 2 step with the new version firmware. And the 2 step,works a bit better . but the rpms keep rising ..they dont stay constant at the set rpm
x99percent x99percent is offline
Car: 2008 135i
Default 05-03-2016, 05:26 AM
It seems like FutureUseD bit2 got boogered up somewhere between 32.2 and 32.4. With 32.4, warm-up is triggered off of oil temp regardless of the bit2 setting.
Default 05-03-2016, 09:19 AM
Seems fine in the code. Since the JB4 logs water temps you can easily verify.
Good. It's still not perfect. But back to where it was before.
Car: 2008 135i
Default 05-03-2016, 10:21 AM
With 32.4, I'm seeing the blinkers flash when oil temps reach >160 while bit 2 is enabled.
On 32.2 with the same settings, the blinker flash would happen when water temp was >160.
Could it be that the blinker flash is going off of oil temp, and the warm-up safety is working as it should? I haven't yet tried to verify.
Default 05-03-2016, 10:54 AM
Ah I see. Yes the warmup blinkers are tied to the oil temp regardless of the FUD setting. I'll adjust that next version.
Car: BMW 335i MT
Default 05-03-2016, 12:40 PM
yeah it works much better. you will just have to really time it so that you have the launch at your desired RPM.
Here is a Video --
https://www.youtube.com/watch?v=IXacfAE7NzQ
Default 05-06-2016, 12:59 PM
Originally Posted by GermanBoy
Hi T.
Is the
If you need tech support throw a log and details in the support forum.
1FastT2 1FastT2 is offline
Default 05-06-2016, 03:54 PM
Are you running a BEF? I only wish mine worked like your....
2008 e92 335i 6MT - On3 Performance Single Kit w/Precision 6266 Gen 2 | VRSF 7" FMIC | VRSF Chargepipe w/HKS BOV | JB4 w/Bluetooth & 2 step and MHD BEF | BMS Meth Kit 2x CM10's | Fuel It Buckless Stage 2 Pump | ADV Sensors | Trebila Tuned
E90M335i E90M335i is offline
Default 05-06-2016, 11:28 PM
Here is a Video --
Works on mine too but kinda on and off.. sometimes it throw a couple misfires with it.. same thing with you nuttifriendivan?
Car: F06 N55 640i Gran Coupe
Default 05-07-2016, 02:18 AM
So 2 steps wouldn't work with BEF?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS DP n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 05-07-2016, 07:06 AM
No I never said that. I have been chasing some issues with mine. Some times it works smoothly sometimes not. I was just curious as to whether he was running one or not.
Default 05-07-2016, 07:41 AM
Oh I see, no worries just asking & want to make sure b4 I install my. Thanks
Moodster123 Moodster123 is offline
Car: 2009 135i
Default 05-07-2016, 10:15 AM
some help please 1addicts.com
Default 05-07-2016, 10:21 AM
1addicts is not a forum we sponsor. I'd delete the post there and make it in the n54tech support forum if you want our assistance with it.
Default 05-08-2016, 04:09 PM
Hey Terry. Is there gonna be anymore adjustment for the 2 step?
Default 05-08-2016, 04:32 PM
Yes there will be further adjustment in future software versions.
