(#2251)
Oryx's Avatar
Oryx Oryx is offline
Car: 2010 535xi
Default 04-02-2016, 09:19 AM
If you are at 11.6 v static charge you need to charge it completely. Fully charged you should be around 12.5v.
If you start inducing a load to a battery with 11.6v you will immediately start dropping and could potentially drop below a min voltage.
Fully charge first and then keep maintaining charge on the system when flashing as it will be cycling fuel pump and other electronics as the flash is programming.
miksebik miksebik is offline
Car: E92 335i
Default 04-03-2016, 12:21 AM
You'd need 20A supply to compansate for the load during flashing. I have 7A charger and with charged battery and connected charger, 40min of flashing are OK.
E92 335i N54, Hexon RR500, JB4, DCI, MMP inlets, ER chargepipe, Turbosmart Kompact Dual Port BOV, ATM IC, Wagner downp*pes, MPerformance exhaust, oil cooler, trebila flash (via MHD Flasher), E60, M Performance 370mm brakes, styling 313 wheels, M Performance suspension, Fuelit Stage2, MFactory LSD, MFactory SMWF
TwistedTuning TwistedTuning is offline
Car: 2007 335xi 6MT Sedan
Default 04-03-2016, 02:50 AM
My 2amp trickle charger works fine this far
"Increasing the Area Under The Curve"
Custom Performance ECU Calibration
www.twistedtuning.com
twistedtuned@gmail.com
JayJ JayJ is offline
Car: 135i N54
Default 04-03-2016, 01:29 PM
Hi Terry
In flashes of 6/6/15 you desensitized knock tables to reduce false knock.
In recent flashes, you reversed these changes to "normal" flashes and added those with KR designation.
Are the knock tables of the new KR designated flashes desensitized MORE aggressively than earlier flashes?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 04-04-2016, 05:58 AM
Originally Posted by brainsurgery
I have latest race flash in at the moment and before I start playing with E85, I wanted to see how it works with 98RON if i have a situation I can't get E85 anywhere.
Here's today's result with map1. I did few hard accelerations before I took the log. My avg ign was 0.9.
Cyl 4 was doing something else than others. I have to keep on eye that one.
Not only Cyl 4 but 5 and 6 too. I'd say this backend is too agressive, but you could try first to enrich the fuel mix. Narly 13 AFR at 4900 is too lean for my taste.
Originally Posted by CLTEURO
If I buy the new maps, is there any way to turn the boost down? Honestly just want to push 15psi and not 18+psi. Looking for Stage 2 since I have *** and an FMIC soon.
I know it's crazy someone asking to turn the boost down :p
The stg1 are targeting 14 psi peak, with just a bit of taper.
Originally Posted by 500hp500tq
Trying to flash back to stock
Does hitting the flash back to stock button
Restore your backup?
Not getting readiness or might have installed the fix wrong
Yes it does. For your puspose, simply swtich to the built in / stage 0 map (2min).
Originally Posted by Dahwich
I have 2 other questions...
1) I noticed that my stock flash was rather old. Is there any reason or benefit to using MHD to flash back to stock (hopefully the newest version) and then reapply the JB4 backend?
2) My car really benefits from the optional wastegate rattle fix (old FUD 98). Does the JB4 backend let you set the cold start noise reduction?
1. By flashing a OTS map or backend, you are already running the most up to date firmware.
2. It's available for backends too.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHD update v1.33 - 04-04-2016, 06:34 AM
Last official update was 1.30, here's the changelog:
04/04/2016 - v1.33
- v6.1 maps open beta testing
- Flash option: MT shift bog fix
- added more slots for flashers, logger & map2 purchases
- DCT: remove the increased boost firmware mod if installed and not needed (MHD OTS, JB4 backends)
- 4 bar sensor fix (0.5 / 4.5V)
The v6 maps are still in beta. Complete rewrite from v5, using stock knock tables like v1-v4 were. The stage 1 and stage 2 now feature 8 maps each (with and without FMIC, 4 octane variants). I recommend running e20 for the 95 octane variants.
Here's the map breakdown:
suspenceful's Avatar
Car: 2008 BSM 135i
Default 04-04-2016, 06:43 AM
04/04/2016 - v1.33
Awesome!
I plan to start with the JB4 MHD E85 backend flash. Will I be able to select the MT shift bog fix? Or does that require me to use a dedicated MHD-created flash?
Hoping to install MHD this week.
🚀 My 750HP 135i build: my1series.com
🔧 My budget 335i build: bmw335i.com
📷 Follow me on Instagram: instagram.com/jakespence
🎬 Watch me on YouTube: youtube.com/jakespence135
🌟 Support me on Patreon: patreon.com/jake_spence
🏁 Shop BMW merchandise: bimmerstreet.com
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 04-04-2016, 07:47 AM
Originally Posted by suspenceful
Awesome!
Yes it's available for backends too. See below the current list of flash option (top always available, bottom stand alone flash only):
Car: 2008 BSM 135i
Default 04-04-2016, 07:52 AM
I'm super excited now. Thanks for the continued development!
DenCo535xi DenCo535xi is offline
Car: 2008 535xi
Default 04-04-2016, 10:40 AM
I was wondering if anyone has used AMIDuOS as an Android emulator on their computer to install MHD? I have a laptop that I can use and am trying to avoid having to buy a separate device just for this.
treehouse treehouse is offline
Default 04-04-2016, 10:46 AM
@MHD Can you provide a bit of technical detail on what the MT shift bog fix does? Thank you
Trickcruiser's Avatar
Default 04-04-2016, 12:54 PM
Sorry if this is already covered and I just missed it... But is there any reason that the JB4_MHD_I8A0S_HYBRID_PUMP.bin is in a test folder when downloading the files?
rays 335i's Avatar
rays 335i rays 335i is offline
Car: 07 335 coupe
Default tuner pro question - 04-04-2016, 12:55 PM
where in tunerpro can i adjust for cold morning turbo rattle? i have tried the mhd flash using 3 different minis and two diiferent cables also 2 diff. tablets using bimmerboost flash right now and had jb4 but sold it on the 335 for newer one....yeah i should have removed it but would very happy to have this answered.
Car: 135i N54
Default 04-04-2016, 01:04 PM
Originally Posted by JayJ
Hi Terry
Bump for Terry
italiabari10 italiabari10 is offline
Default 04-04-2016, 03:25 PM
Too many pages to go through. If this has been covered I apologize. Looking at starting my car up after the single turbo was installed. I can't find my k-dcan cable for the MHD flash(ordering another). If I upload the jb4 single turbo interface and keep my e85 backend flash will I be fine to start the car to check for leaks?
09 135i, BW S366, jp works top mount manifold and D0wnp1pe, tial mvs 38mm, VRSF 7" FMIC, JB4 w/MHD ST flash, mac, 3.5 tmap, 255 fuel pump, agency power midpipe, ER Charge pipe W/ tial, Vogtland coilovers, M3 subframe bushings, VMR 710 matte black, Alpina B3 flash.
Default 04-04-2016, 04:01 PM
Sure. Just don't go WOT until loading the proper single turbo back end flash map.
dr.george dr.george is offline
Car: 135i 6 speed MT
Default 04-04-2016, 04:09 PM
whats the cheapest android phone suitable for running MHD properly?
Levan-i's Avatar
Levan-i Levan-i is offline
Car: 2007 BMW 335i E92
Default 04-04-2016, 04:53 PM
i like mhd more and more,
wondering when bluetooth/wifi version will be available,
and wondering if you plan to have boost target change only flashing.. like changing maps on jb4
also, you could show MT options in case if car does not have 205 option in VO only, it would simplify interface for users.
2007 E92 335
ST - GTW3684
JB4 G5, ST Pump Flash, Fuel-It Stage 1, Meth
MT (after swap),
MFactory LSD
rays 335i's Avatar
Car: 07 335 coupe
Default 04-05-2016, 09:25 AM
terry or anyone??? no one has tuner pro to change anything??
ThaCuda's Avatar
ThaCuda ThaCuda is offline
Default 04-05-2016, 10:33 AM
Cold start: It's under options when you flash... full or BEF.
2007 335i 4dr JB4, Hexon RR600, Inlets, 4Bar, Index 12, Boost Concept Pump, DCI, FMIC, DP and full exhaust, Burger Meth, MHD BEF. Auto.
Blaster400's Avatar
Blaster400 Blaster400 is offline
Car: 2007 BMW 335 E92
Default 04-05-2016, 11:52 AM
Exactly how dangerous is it running the KR option? I can control my fuel octane but I can't control all the other factors that could cause knock.
JB4 G5 w/BMS MHD backend flash | MOTIV 750 | 100% E85 | MOTIV port injection | Fuel-It Stage 3+ LPFP | Akrapovic Exhaust | DSS Axles | DEFIV lockdown kit | Quaife LSD
Car: 2008 BSM 135i
Default 04-05-2016, 11:53 AM
Also curious on this. I'll be loading my MHD flash this weekend and don't know if I should go with or without the KR on my E85 BEF.
Default 04-05-2016, 12:07 PM
Start with the normal map and evaluate your timing. If the drops are coming up at lower boost levels, etc, then they are likely to be false. If timing is good at low boost but bad at high boost then it's likely real knock.
rays 335i's Avatar
Car: 07 335 coupe
Default 04-06-2016, 04:22 AM
thanks for the reply. i want to change using tuner pro, i dont have mhd, or jb4 using BBflash to change stock flash
n54wagon n54wagon is offline
Car: 2008 535xi touring
Default 04-06-2016, 05:52 AM
Hello,
This is my first post, I'm new to the online BMW community. I've always had german cars, just never BMW's. Recently I purchased a 2008 535xi touring (AT), I absolutely love it. These forums have been great...
So on to my car - The only things I have done to it is add an afe intake and I bypassed the exhaust flap solenoid in the boot of the car.
I added the MHD stage 1 V5 93 octane map on my car last week. My initial thoughts were I loved it of course. Its definitely a smooth map. My car pulls hard, shifts smoothly, and sounds amazing. I've never heard this much airflow from stock turbos before (I've had several turbo cars including my past favorite the audi 2.7 bi turbo). This map definitely did the trick and for the money it's a steal. I paid 4 times as much for my APR audi tune years ago....
So here is the only negative issue I have personally had with the MHD tune. After installing it into my car within the first 24 hours my car started up 2/6 times and threw itself into limp mode while in park. Then the next day pulling slowly out of my driveway in drive the car threw itself into neutral and then limp mode, also giving idrive error park may not work. As these issues are a little annoying they aren't deal breakers (unless this happens while I'm going a decent speed or in traffic).
Each time these errors happen I just simply shut the ignition off remove the key and arm and disarm the alarm and the issues are gone... So it hasn't been a deal breaker yet. Before the MHD the car never once had any issues...
Yesterday I installed the new V6.1 and I also did the limit power per gear option. I limited boost to 1st-5psi 2nd-10psi 3rd-15psi. I didn't really have any real theory behind my limits they just sounded reasonable to me. So far its been 24 hours and I have only started the car 3 times, all without issue.
I will give updates as I drive more and more.
Again, I really LOVE this flasher and tune. MHD is an amazing app. These little software hiccups haven't been a deal breaker.
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
mkolankowski
