(#9951)
Timed to go's Avatar
Timed to go Timed to go is offline
Car: 2007 335i sport package jb4 g5 iso BMS DCI
Default 10-31-2015, 12:59 PM
Only problem now is that gas is going empty and full like crazy anytime i press gas pedal!!![/QUOTE]
Sounds like gage hijacking.
http://www.n54tech.com/flash_files/jb4_wheel_1.jpg
2007 E92 335i sport package 6mt jb4 g5 iso Fw 31.8
BMS 7/1 pump flash, DCI, OCC, clutch valve,
VRSF dp, 7.5 IC, Inlets, CP, tial bov.
12 & 15 mm Wheel spacers, Lux V5.
freakbmw freakbmw is offline
Car: 2008 335i
Default 10-31-2015, 03:28 PM
That will do the trick!!!
I'll let u know when done...
2008 335i A/T, JB4 G5, CPE DP's, BMS DCI, BMS CP WITH TIAL BOV, MAGNAFLOW EHXAUST...😈😈😈
Traf Traf is offline
Car: 2009 135i Coupe
Default 10-31-2015, 05:27 PM
Tried 31.8 with menu 11 at 5000 and menu 12 at 2k5. Jerkiness on light throttle is gone, everything seems cool.
f*** v-bands clamp
Bullitt1841's Avatar
Default 11-01-2015, 11:57 PM
Does anybody have the Stock Flash JB4 default settings they can post? The screenshot has been removed from all stickies that I can find
Default 11-02-2015, 08:36 AM
It's in the 3rd post.
Default 11-02-2015, 06:19 PM
Understood.
For clarification for anybody else, there are now only one set of AFR Bias values for stock or backend flashes.
Dcara Dcara is offline
Default 11-02-2015, 09:57 PM
I was wondering if anyone could chime in on if this is fine to run for the winter.
I have a jb4 and run it in map 5 and mode 42 with the mhd backend pump flash. For winter I'm planning on running map 0 on the jb4 because with all the snow we get I have no need for the extra power. Will everything run fine if I leave the mhd pump flash with jb4 set to map 0 with option 4 2 enabled?
Thanks.
Default 11-02-2015, 10:00 PM
Use map4 for stock performance on ISO firmware.
Default 11-02-2015, 11:07 PM
Thanks terry.
should I leave option 4 2 enabled?
Car: 2008 335i
Default 11-03-2015, 05:18 AM
Thanks everyone for the support, car's just running fine with no codes or errors for now!!!
Default 11-03-2015, 08:37 AM
Originally Posted by Dcara
Thanks terry.
If you have our back end flash map loaded, yes you leave it on 4/2.
Stucks Stucks is offline
Default 11-04-2015, 04:30 PM
Originally Posted by dawhiz
5) If using a 3.5bar TMAP sensor you need to set "N20 TMAP" to 1 after installing it, and also realize your FF/duty bias values will be approx 20% lower than they were with the 2.5bar factory sensor. An easy way to offset this is by setting your duty bias to 65 across the board instead of 50 (or 0) across the board to rerange the FF parameter.
Does this apply to if we have a backend flash (since 0 is mentioned)? Should we have the duty bias set to 0 if backend flash & 3.5 or should we adjust it to 65 (assuming 15 would then be the same in this sense?)
this is from post 9944......any more info on this? it seemed to have been skipped over and forgotton about lol
Setting all duty bias tuning rpm fields to 50 would essentially disable it (like when I had it set to 0 before) regardless of what fud is set to, right?
Current: 2008 e92 335i coupe.
Car: 335i e90
Default 11-05-2015, 10:06 AM
Terry, curious if you could update the interface to allow steering wheel control past 10, blew out my clockspring and until I get a new one I can't adjust settings in menu 12 form the laptop. Any options?
'07 e90
davida915 davida915 is offline
Car: 2007 BMW 335i
Default Which jb4 do I have? - 11-05-2015, 01:41 PM
I have a jb4 with two boxes. Is this G4 and what firmware would I need. Also do I need the other box once I upgrade to G5?
Car: 2007 BMW 335i
Default Other box - 11-05-2015, 01:42 PM
What's this for?
dorci's Avatar
dorci dorci is offline
Car: 135i 09'
Default 11-07-2015, 05:30 AM
Hello, the last update 31_8 affect the 2step during the procédure.
The rpm increase and decrease and never stay to my rpm settings.
It is Just me or it's due to the New firmware ?
Selene's Avatar
Selene Selene is offline
Car: 2008 Sapphire black 135i
Default 11-07-2015, 09:41 AM
Did you read the firmware release notes at all?
Check note 5...
5) Change to the 2STEP logic to improve fueling coming out of a 2TEP. The changes may also effect the 2STEP RPM targeting. Needs testing.
... I've noticed the same thing and I think Terry is working on it :-)
'08 135i 6-Speed... BMS Pump Flash, BMS JB4 G5, BMS 3" ***, BMS OCC, RB PCV, VRSF 5" Stepped FMIC, aFe DCI, Racewerks Charge Pipe w/ TiAL Q BOV, Modified Berk Exhaust
Default 11-07-2015, 02:12 PM
The 2STEP targeting isn't perfect, but works as well or better than previously.
dorci's Avatar
Car: 135i 09'
Default 11-07-2015, 11:59 PM
Check note 5...
Yup I read it but don't work really.
The antilag works very well.
Terry do you think it s dangerous to got 19 psi with cats ? I use sp98 and 70% e85
///Monst3r ///Monst3r is offline
Car: 07 335i
Default 11-09-2015, 07:10 PM
Will this not work on a 32bit system? I'm having trouble installing on winxp 32bit.
07 e92 MT 335i- JP works TS TM 6466 1.0 a/r, custom 4in fmic, vrsf cp, tail bov, custom catch cans, external pcv mod, adv O2's, phoenix intake manifold,fuel it port injection, bms meth kit dual cm10, Motiv twin disk, 450/540 in tanks/ 6an return and regulator, stoptech drilled and slotted rotors & pads,15in drag setup , ST coilovers,berk full exhaust ,jb4 g5, mhd
2012 650i- D0wn pip3s, jb4, custom drop in filters, carbon filter delete
Default 11-09-2015, 07:38 PM
No known issues with 32bit systems.
Default 11-09-2015, 07:39 PM
With E85 EGT is going to be much lower than it would be on petroleum, so its probably fine.
Timmay77 Timmay77 is offline
Car: 2008 535xiT
Default 11-10-2015, 02:40 AM
Terry,
Would it be possible to have a constant on output for "engine temp ready for full boost", so to speak. I know the JB4 can flash the hazards when operating temp is reached for full boost.
The reason I ask, is it would be nice if the JB4 connect kit could display a very small indicator on the display screen of when the engine is at temp. Light a small green light or something. He can not do so unless there is an output that stays on once the engine is at temp instead of just a momentary indicator, such as flashing the hazards.....
2014 328i xDrive Msport
Trickcruiser's Avatar
Default 11-10-2015, 04:52 AM
Originally Posted by Timmay77
Terry,
This would be a nice add for the 5 series guys (and anyone else whe does not have a oil temp gauge).
Default 11-10-2015, 09:01 AM
Terry,
We could work something out with Donnie on that. What if we had it hold the JB4 in map4 when not up to temp then map switch once it is?
Currently Active Users Viewing This Thread: 15 (2 members and 13 guests)
SkrillaE60, Vorsprung_CJB
