(#1551)
rocky335i rocky335i is offline
Car: e92 2007 335i
Default 10-07-2015, 08:56 PM
When changing from the pump backend flash and e85 backend do i need to flash back to stock then load the e85 backend? Or can i just overwrite the pump flash and load the e85 one?
1fastgsrturbo 1fastgsrturbo is offline
Default 10-07-2015, 09:27 PM
I switch back and forth between pump flash and race flash. Only the first flash takes the longest 36 mins but every time I switch between backend flashes it only takes 2 mins and basically overwrites the other flash. My experience (fbo 335i pump w/meth)
Car: e92 2007 335i
Default 10-07-2015, 09:48 PM
Ok thanks
maikayou's Avatar
maikayou maikayou is offline
On Notice!
Car: BMW 335i 7AT DCT
Default 10-08-2015, 06:34 AM
Hello,
I have recently bought the app (monitor + flasher). I have also uninstalled Cobb from my car.
I am about to flash one of the built-in maps. Is there anything that I should be worried about?
Is it straightforward?
Are the built-in maps for US spec cars only? Or including Euro too?
erwan35's Avatar
erwan35 erwan35 is offline
Car: bmw 335i e92
Default 10-08-2015, 09:18 AM
And since i hv the 3.5bar tmap sensor installed. Do i still need to get the mhd maxboost adapter?
_______________________________________\\\
BMW 335I E92 2007 RHD 6AT,FULL M3 BODYKIT,HYBRID TURBOS,BMS ADAPTER W/ 3.5BAR TMAP,VTT INLETS,JB4 G5ISO W/ MHD TREBILA FLASH,BMS ANTI-LAG,AEM METH KIT W/ FSB,BMS DCI,VRSF CHARGEPIPE & TIAL BOV,VRSF C@TLESS ***,FMIC,BMS OCC,BMS CABIN FILTER,MUFFLER CUSTOM BULLET,97RON PUMP GAS
yournamehere90 yournamehere90 is offline
Car: 2008 535i
Default 10-08-2015, 10:13 AM
Originally Posted by maikayou
Hello,
It's very straightforward. They recommend a battery charger during the flash. I used one whole flashing my 135i and didn't use one while flashing my 535i but it has a new battery. Make sure to turn the headlights to the off position. Flash will take 38-39 minutes on a 08+ car. I'm happy with mhd
blisstik's Avatar
blisstik blisstik is offline
Car: 2007 E92 MOTIV 750
Default 10-08-2015, 10:16 AM
Everyone should really be using a battery tender and charging your battery once every 3 months to extend the life of your battery. Unless you like paying $500 for a new one.
MOTIV750 / MHD+JB4 / ADV / SB REAR O2
maikayou's Avatar
On Notice!
Default 10-08-2015, 10:59 AM
should be easy for you as the maps are for us specced cars
Car: 2008 535i
Default 10-08-2015, 02:42 PM
There is a member of e90*post in Australia who says he was able to use US stage 1 but it's a tad aggressive for the fuel. I'm not sure if Euro spec and Australian are the same but he made it seem that they are.
rays 335i's Avatar
rays 335i rays 335i is offline
Car: 07 335 coupe
Default 10-08-2015, 03:12 PM
i am sure its been mentioned before but can the bt cable be used to flash mhd?? about to sign up for this...just need to know.
PLF's Avatar
PLF PLF is offline
Default 10-08-2015, 03:16 PM
NO
YES it was mentionned million times...
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-09-2015, 12:53 PM
The BMS backends flashed with MHD are US canned bins. The MHD stand alone maps are applied on top of the regional OEM map suited for each car. If a 93 map is too agressive for your fuel, you can run the 91 variant.
Jcoccy335 Jcoccy335 is offline
Car: 2006 335i
Default 10-09-2015, 01:36 PM
Hi all.
Been searching for figures and numbers and can't find anything that sums it up.
I've got a 2007 335i AT with jb4 g5 and am going to upload the bms mhd backend pump flash.
Obviously there's allot of efficiency benefits engine runs smoother. Better timing etc.
What kind of hp gains/specific improvements can I expect to see/feel when I flash. I could dyno before and after but that's not so easy for me but if anyone can help me out incase the improvements are so subtle that it's difficult to tell with a butt dyno that it's actually done anything.
Cars a daily driver or more of a weekend warrior but never gets tracked or raced.
Appreciate your advice.
J
2006 e92 monaco blue
Jb4 G5 ISO
Bms dci
Bms 3" *********
Forge cp and twin BOV
Bilstein b12 kit
If it ain't broke, break it.
Welterweight Welterweight is offline
Car: E92
Default 10-09-2015, 06:50 PM
Ok guys I have the right cables and the $99 app. What's the next step? MHD Built in maps? Wedge? SPX? Thanks!
Mikewills Mikewills is offline
Car: 1M
Default 10-09-2015, 07:07 PM
I'm currently working with Ken on a Wedge etune because my 1M didn't like the OTS maps. What mods do you have? Any plans for more upgrades?
Car: E92
Default 10-09-2015, 07:23 PM
Worked with Wedge on COBB. I am FBO with E85 and inlets on the way.
HunterR HunterR is offline
Car: 07 335i
Default 10-10-2015, 12:38 AM
My Kline is usually finicky with flashing but this is just strange.
Car will connect with ignition in stage 1 but with Stage 2 it's unable to connect.
Able to buy flasher and map outside of ignition on so that's what I did. Could this be the cable, otg cable, my phone or car?
erwan35's Avatar
Car: bmw 335i e92
Default 10-10-2015, 03:10 AM
I really need help here
Mr. T Mr. T is offline
Default 10-10-2015, 12:14 PM
If you're stacking the jb4 and using mhd to load backends you spent too much money. You needed the $79 jb4 backend.
Car: 07 335i
Default 10-10-2015, 03:33 PM
Any idea on ways to tell if it's my Dcan or otg cable? Connections are intermittent and never when ignition is on
Bullitt1841's Avatar
Default 10-10-2015, 03:58 PM
Are the new "HYBRID" changes going to make their way into the PUMP or RACE maps, too?
Car: 07 335i
Default 10-10-2015, 04:07 PM
Update, says high powered usb device connected, does my phone not have enough juice to reflash?
Nniftyfour's Avatar
Nniftyfour Nniftyfour is offline
Car: 335xi
Default 10-11-2015, 07:48 AM
No somethings wrong with your OTG cable or phone. The cable gets powered from the OBD port, only data goes to and from the android device.
Default 10-11-2015, 05:51 PM
Originally Posted by MHD
Here is the change log for the 09/24 (v1.10) update:
- map updates are 10s faster (other modules code clearing removed)
What is the purpose of not clearing all other modules after a map write? I now have to manually clear these modules and their codes every time I change maps.
Now the overall process is much, much longer than the original time, not 10 seconds faster.
Blind35 Blind35 is offline
Car: 335Xi '08 N54
Default 10-12-2015, 01:45 AM
hello
i have FBO and !!!JB4 G4!!!
can i flashing PUMP MAP?
or it's map only for JB4 G5 ISO???
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
angelo.nikolakakis
